    Vray Render result problem help needed
    renderpluginsextensions
    6 Posts 3 Posters 1.5k Views 3 Watching
    • N Offline
      nawaitsa
      Help needed
      I'm new to vray and i have a problem with my rendered images, as you can see when the render finished something bad happen with the result, the white colour on the scene somehow became blurry and not very clear.
      http://i47.photobucket.com/albums/f200/nawaitsa/1sthelpcopy.jpg
      I use Irr with blue sky colour multiply 3 and i use a sky background enviroment.
      I'm stuck so any help and support will be appreciate thanks
        Need more info.
        What V-Ray version do you use?
        What is your setup? IR + LC?
          steelers05
          yeah it is hard to help without knowing your settings...but i think if you put a rectangular light right inside of your window to increas the amount of apparent light coming from the outside will help get rid of some of the splotchiness. Maybe increase the sub-division of your light cache if that is what you are using for secondary bounces in your rendering setup.
          • N Offline
            nawaitsa
            @thomthom said:
            Need more info.
            Thanks for your replies thom,, I'm using IR. Does the lackness amount of light affect this result?
            • N Offline
              nawaitsa
              Thanks for the info steelers, Im using Irradiance -3/0 my subdiv is set 50. I'm using default camera. I'm sorry guys to bother you,.. I'm very thankful for your replies. I'll try your info steelers. Thanks
                steelers05
                no problem...good luck
