    Needs some small assistance
    9 Posts 3 Posters 745 Views 3 Watching
    • P
      Peterbilt1993
      I need a little help with the hood of my truck...the pic will tell u
      the path of the red line...i need a line going that all the way around the hood so i can make that front part silver along with that bottom part...if u no what i mean if someone could help it would be very much appreciated!
      SW16
      My Warehouse link: https://3dwarehouse.sketchup.com/user.html?id=u92a62fb3-fd89-42e5-b424-55d0babc2274
      • GaieusG
        Insert a (grouped) plane/face in there (bigger than the hood), select the hood (if it's a group, enter the group first) and right click > intersect with model.
        Those dividing lines should appear.
        • P
          Peterbilt1993
          k ill try that thx alot!
          SW16
          • GaieusG
            Isn't that a different group/component by any chance?
            • P
              Peterbilt1993
              i seemed to of gotten some of it but having trouble with the other half...
              maybe if someone could fix it cuz i have no idea what i am doing lol
              petehood05.skp
              SW16
              • P
                Peterbilt1993
                the hood is all one group...i followed ur advice and it only did half so idk
                SW16
                • GaieusG
                  Well, in that case it should have done both sides. I don't know why it didn't
                  • P
                    Peterbilt1993
                    idk its messed up...im like confused lol idk what to doo
                    SW16
                    • D
                      d12dozr
                      Just "intersect with model" as Gaieus says again for the other side...it worked fine for me.
                      I had a look at your model...its looking pretty good so far. If you use more components, your modeling will speed up significantly. For example, each headlight should be a component(and would look better if it was smoothed and the circle it was constructed from had more segments). If each of the vertical bars on the grill was a component, you could copy an array to space them perfectly. Maybe you would have a hard time modeling this way, but if you split the model in half the long way, make it a component, copy/flip to the other side, then you only have to model half as much because whatever you do to one side automatically happens to the other side. πŸ˜‰
                      Like this:
                      Make one-half a component
                      Copy, flip and hide the center lines
                      Move them together and just model on one half
                      There are a lot of tricks to help you to model faster - have a look at these tutorials if you haven't already: http://sketchup.google.com/training/videos/familiar_with_gsu.html An hour invested here will save you countless hours and headaches down the road! I hope this helps, cheers!
                      http://goo.gl/f7ooYh
