Needs some small assistance
I need a little help with the hood of my truck...the pic will tell u
the path of the red line...i need a line going that all the way around the hood so i can make that front part silver along with that bottom part...if u no what i mean if someone could help it would be very much appreciated!
Insert a (grouped) plane/face in there (bigger than the hood), select the hood (if it's a group, enter the group first) and right click > intersect with model.
Those dividing lines should appear. -
k ill try that thx alot!
Isn't that a different group/component by any chance?
i seemed to of gotten some of it but having trouble with the other half...
maybe if someone could fix it cuz i have no idea what i am doing lol
the hood is all one group...i followed ur advice and it only did half so idk
Well, in that case it should have done both sides. I don't know why it didn't
idk its messed up...im like confused lol idk what to doo
Just "intersect with model" as Gaieus says again for the other side...it worked fine for me.
I had a look at your model...its looking pretty good so far. If you use more components, your modeling will speed up significantly. For example, each headlight should be a component(and would look better if it was smoothed and the circle it was constructed from had more segments). If each of the vertical bars on the grill was a component, you could copy an array to space them perfectly. Maybe you would have a hard time modeling this way, but if you split the model in half the long way, make it a component, copy/flip to the other side, then you only have to model half as much because whatever you do to one side automatically happens to the other side.
Like this:
There are a lot of tricks to help you to model faster - have a look at these tutorials if you haven't already: http://sketchup.google.com/training/videos/familiar_with_gsu.html An hour invested here will save you countless hours and headaches down the road! I hope this helps, cheers!
