    Direction of Pushpull Is ?
    11 Posts 4 Posters 1.3k Views 4 Watching
    • M
      MartinRinehart
      ents = Sketchup.active_model.entities
      f = ents.add_face ...
      f.pushpull x
      Which way does that pushpull?
      Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
      • J
        Jim
        Always in the direction of the face normal. Modify your question a little.
        • Chris FullmerC
          Except if the face is lying flat on the ground. In that case, it is always pushpulled in the positive Z direction (upwards), regardless of its normal's direction.
          All my Plugins I've written
          • TIGT
            So [usually] if it faces up it pulls 'up' and if it faces down it pushes down...
            If you always want it to be pulled 'up' then face.reverse! if face.normal.z<0; face.pushpull(dist)
            but if you want it pushpulled in the direction of the face's normal then plain
            face.pushpull(dist) will work except if face normal==[0,0,1] and face.bounds.min.z==0 in which case adjust accordingly...
            • J
              Jim
              I didn't want to spoil it - Martin seems like the kind of guy who enjoys figuring things out.
              I think it was trick question.
              • M
                MartinRinehart
                No quite. I knew, before I asked, that the answer was "positive distance is often toward the outside of the face" and that a fresh rectangle in the rg plane was an exception. What I didn't know was if the latter was THE exception or one member of a class of exceptions.
                • J
                  Jim
                  Yes, but I am not seeing any exception.
                  Using this code, I get the following model - one face pushed up, the other down.
                  model = Sketchup.active_model
                  entities = model.entities
                  selection = model.selection
                  selection.each {|e|
                    if e.is_a? Sketchup;;Face
                      e.pushpull(10)
                  pptest.skp
                  • Chris FullmerC
                    Well that's odd. I could have sworn that a face on the ground plane will always head upwards.
                    Chris
                    • M
                      MartinRinehart
                      Me too. I just rectangled twice on the ground plane, reversed one of the faces.
                      This, from memory, was what I typed into the Ruby Console:
                      f = []
                      ents.each { |e| f.push(e) if e.is_a? Sketchup;;Face }
                      f.each { |f| f.pushpull(10) }
                      Result: two rectangular parallelepipeds (that's pretentious for "box"), both with their blue dimensions ranging from 0 to 10.
                      So now we've really screwed this one down: always toward the outside face, except on the ground plane, but the exception doesn't apply to Jim.
                      Anyone happy with this?
                      • M
                        MartinRinehart
                        Totally wrong! Went back and did it again, carefully, being sure to orbit around and under. Jim is right. Sorry, Jim.
                        • J
                          Jim
                          Maybe version 6 behaved differently? I can check...
                          No, 2 faces on the RG plane with opposite normals, +Z and -Z, each pushpulled +10, each extruded in the direction of the normal - so one went up, the other went down.
