    Direction of Pushpull Is ?
    11 Posts 4 Posters 1.1k Views 4 Watching
      MartinRinehart
      ents = Sketchup.active_model.entities
      f = ents.add_face ...
      f.pushpull x
      Which way does that pushpull?
        Jim
        Always in the direction of the face normal. Modify your question a little.
        • Chris FullmerC Offline
          Except if the face is lying flat on the ground. In that case, it is always pushpulled in the positive Z direction (upwards), regardless of its normal's direction.
            So [usually] if it faces up it pulls 'up' and if it faces down it pushes down...
            If you always want it to be pulled 'up' then face.reverse! if face.normal.z<0; face.pushpull(dist)
            but if you want it pushpulled in the direction of the face's normal then plain
            face.pushpull(dist) will work except if face normal==[0,0,1] and face.bounds.min.z==0 in which case adjust accordingly...
              Jim
              I didn't want to spoil it - Martin seems like the kind of guy who enjoys figuring things out.
              I think it was trick question.
                MartinRinehart
                No quite. I knew, before I asked, that the answer was "positive distance is often toward the outside of the face" and that a fresh rectangle in the rg plane was an exception. What I didn't know was if the latter was THE exception or one member of a class of exceptions.
                  Jim
                  Yes, but I am not seeing any exception.
                  Using this code, I get the following model - one face pushed up, the other down.
                  model = Sketchup.active_model
                  entities = model.entities
                  selection = model.selection
                  selection.each {|e|
                    if e.is_a? Sketchup;;Face
                      e.pushpull(10)
                  pptest.skp
                    Well that's odd. I could have sworn that a face on the ground plane will always head upwards.
                      MartinRinehart
                      Me too. I just rectangled twice on the ground plane, reversed one of the faces.
                      This, from memory, was what I typed into the Ruby Console:
                      f = []
                      ents.each { |e| f.push(e) if e.is_a? Sketchup;;Face }
                      f.each { |f| f.pushpull(10) }
                      Result: two rectangular parallelepipeds (that's pretentious for "box"), both with their blue dimensions ranging from 0 to 10.
                      So now we've really screwed this one down: always toward the outside face, except on the ground plane, but the exception doesn't apply to Jim.
                      Anyone happy with this?
                        MartinRinehart
                        Totally wrong! Went back and did it again, carefully, being sure to orbit around and under. Jim is right. Sorry, Jim.
                          Jim
                          Maybe version 6 behaved differently? I can check...
                          No, 2 faces on the RG plane with opposite normals, +Z and -Z, each pushpulled +10, each extruded in the direction of the normal - so one went up, the other went down.
