    Dynamic Hole
    7 Posts 3 Posters 1.7k Views 3 Watching
      markozeta
      Dynamic components seem to have an issue with holes.
      So, I decided to try to make one on my own.
      Let me know what you think.
      Mark
      ![Flange at 4"](/uploads/imported_attachments/QpaM_DynamicHole4.jpg "Flange at 4"")
      ![Flange at 60"](/uploads/imported_attachments/BrjN_DynamicHole60.jpg "Flange at 60"")
      Improved with deleted edges!
      BSME - Cal Poly Pomona
      Sketchup Pipe Maniac
      • Chris FullmerC Offline
        That's great Mark! That looks like it took a lot of work to get right, but its great. The only thing I would suggest is to go into each component that makes up the component, and delete the inside walls. That will help it display more smoothly. Then it will not be noticeable that it is made up of many many pieces.
        Really cool!,
        Chris
        All my Plugins I've written
          markozeta
          This suggestion was a real help. See attached the improved version.
            Great DC now with the improvements that Chris suggested. If only i could grasp how you did it?
              markozeta
              C:\Program Files\Google\Google SketchUp 7\Components\Dynamic Components Training\Pie.skp
              Apparently this is a model that I found on my desktop with a radial array. Don't know if it came with it, so I attached it as well.
              1 hour of reverse engineering Pie.skp + wikipedia + 5 hours straight of trial and error = dynamic flange.
              Mark
              File that came with sketchup?
                markozeta
                Maybe this will help explain the subject a bit better.
                I think this reasonably explains how the component works, without going over the top with the technical.
                Then again, trig was my favorite subject in school, so I know that some things in trig that seem obvious to me are not obvious to others. Let me know if I was too technical.
                Mark
                Guide Explaining How the Dynamic Hole works
                  Thanks for the explanation/tutorial on how you achieved this DC. Makes for very interesting reading and deserves a bit more attention than it is currently getting.
                  I hope more users check this post out to see how much work goes into such a simple concept.
