    [Plugin] Blend ver 1.12.
    80 Posts 35 Posters 69.1k Views 35 Watching
      Come on, Kirill, this is too much for me today. 😮 😲 😕 😒
      • EarthMoverE Offline
        EarthMover
        Mr Krillshot....fantastic work and dedication to continually improving your script. Can't wait to see v. 1.8! Thanks so much!
        Content Creator at Skapeup
        • kenK Offline
          ken
          Mr Krillshot
          Great pluging, however, I am having trouble duplicating all the video you are showing. Would it be possible to also attach the Sketchup file so I can try out the same file as you are using. This way I would know if the problems I am having are with my computer or the plugin.
          Again thanks for the pluging
          Ken
          • utilerU Offline
            utiler
            This is nuts; really. I can't beleive how fast you are developing this plugin, Mr Kirill!!!
            Just Curious...
            • K Offline
              kirill2008
              interactive tests file
              File with the model, that appears in the demo video of ver. 1.8.
              Unfortunately interactivity enabled only in run-time (untill skp file is not closed) and I don't know yet how to save interaction data to skp file (maybe it's not possible at all). So if you want to play with initial faces, then it is necessary to make new blended object.
              Ver. 1.8. does not support interaction with curves yet, because it is difficult to get the curve object from the Sketchup.active_model... The point is that active_model contains no curves (curve is just a 'conceptual entity' "all circles, arcs, and arbitrary curves are really just edges that are bound together in sequence"). So it's necessary to perform some tricky things to obtain the certain curve, that you need.
              Edges also behave strange: moving of the edge or moving of the edge vertex does not envoke onChangeEntity event handler 😕. Only if you change some properties of the edge (for example layer or smoothness), then modify event rises and onChangeEntity envokes.
              [flash=425,344:2o85cxyz]http://www.youtube.com/v/ZgOUZR3Z2xE&hl=ru&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:2o85cxyz]
              So ver. 1.8. supports interaction only between 2 faces and face+construction point. I'm not sure if I can solve myself edge and curve problems.
              • MALAISEM Offline
                MALAISE
                It's amazing the way you progress. I hardly have time to test the current version, and you're already publishing the next version....... 😄
                Thanks a lot for sharing.
                MALAISE 👍 👍
                • P Offline
                  PRSS
                  Fantastic, I say !!!
                  With best regards
                  PRSS
                    tomot
                    @kirill2008 said:
                    @utiler said:
                    Have you thought about adding a path function to this script?
                    Yes, I think about it almost every day (and some times night 😄 too). I want to add a path processing very much,
                    Yes I have been there too 😄 sometimes I have even dreamed of the answer, but forgot to write it down just before I woke up. Then later I would get a deja vú moment where the solution I eventually arrived at was the same as what I had dreamed of.
                    I like the path idea.
                    my plugins
                    tomot
                    • utilerU Offline
                      utiler
                      Here's the idea.....
                      See the attached video example and finished result.
                      Copy an object a given distance, scale it by 0.6 and rotate it 40 degrees AND DIVIDE BY 4.
                      Can't be too hard couldn't it?
                      Blend_Idea.swf
                      Just Curious...
                      • K Offline
                        kirill2008
                        That's cool 👍 It is a step to complex path+profile modeling tool, I guess. Looks like, the final destination is to set some 'key' positions along the path and apply some transformations (move, rotate, scale) to the profile at each 'key' position. Intermediate steps transformations (between key positions) will be interpolated between 'key' transformations.
                        Some 3d modelling programms have already implemented similar tools. It would be great to implement such tool for Sketchup too. Don't know how much time it may take.
                        • I Offline
                          iamarchitecture
                          Fantastic Plugin, Thanks.
                          • MALAISEM Offline
                            MALAISE
                            Now, let's draw icebergs...or coloured curtains easily....
                            Colors effects are awsome
                            Thanks Kirill 👍 👍
                              Ben Ritter
                              Thanks again.
                              • K Offline
                                kirill2008
                                Now the work on path processing feature is in progress. For now it works stable only when the path curve is at XY plane. So I'm going to publish new plugin 'pathface.rb', when it will be possible to follow the path curve regardless of it's orientation (it will take about several days, I think).
                                [flash=425,344:1244ddom]http://www.youtube.com/v/z-IO3YLPTeY&hl=ru&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"[/flash:1244ddom]
                                  sepo
                                  Fantastic.. 👍 👍
                                    DIEGO-RODRIGUEZ
                                    incredible plugins, thank you very much
                                      cokea
                                      even v1.7 and the lower works well, 1.8, 1.9 gives a notice like this "Error Loading File sublend.rb
                                      undefined superclass `EntityObserver'" HELP
                                      • utilerU Offline
                                        utiler
                                        That's great you like it Kirill, Hope you can find the time to bring it to fruition..... your work here and generosity is appreciated by all!! 🎉 🎉 🎉
                                        Just Curious...
                                        • mitcorbM Offline
                                          mitcorb
                                          Hi, Kirill:
                                          Just want to report this observation:
                                          I did a simple blend procedure where I made a rounded corner rectangle on xy plane, copied and raised it up in the z direction, and scaled it then shifted it in the y direction. The blend completed. But when I selected the top plane and attempted to scale it, the intermediate blended geometry disappeared from the file. I did not check the console to see if any error comments came up, as I do not customarily keep the console open.
                                          Any ideas on this?
                                          • H Offline
                                            Haru
                                            “Blend” is awesome plug-in.
                                            Nevertheless, somewhat, it doesn’t work right way in connecting two different faces and it occurs twisted face unrelated to design-purpose.
                                            It can be fixed with the vector that gives the drawing order, but sometimes, it is difficult to reform the design.
                                            Therefore, as I thought, it can be possible to make it right with adding another vector to this plug-in.
                                            As following down-below example of case 1 and case 2, it shows two different cases made by different start points.
                                            In order to make the blended face right to designer’s intention, each start-point of two figures(①,③) shall be set-up as well as the direction of drawing, that is clockwise(②,④) or counterclockwise.(②,④-a)
                                            For all, it’s just an idea; unfortunately, I’m not good enough to make the plug-in.
                                            I anticipate that someone has intention to make this vector and post it on the blog in near soon.
                                            • 3 / 4
