    [Plugin] Layer manager
    54 Posts 32 Posters 67.5k Views 32 Watching
    • Didier BurD Offline
      Didier Bur
      @bagatelo: No... 😞
      DB
      • H Offline
        haiarchi
        Can you set to Tool of sketchup to shortcut in sketchup
          tulacong
          @didier bur said:
          Hi all,
          Time to release the new version of my Layer Manager. Many new tools and enhancements, new toolbars.
          Unzip in your Plugins folder. PDF doc included in the Layer Manager sub-folder.
          [attachment=0:ea3yl9sk]<!-- ia0 -->lmtb.jpg<!-- ia0 -->[/attachment:ea3yl9sk]
          Features list:
          Tools:
          Set layer of clicked object current
          Set layer of clicked object current and isolated
          Set layer of clicked object invisible
          All layers visible
          All layers invisible (except current)
          Toggle visibility of all layers
          Select/Deselect layer content
          Move selection to current layer (digs in compos and groups)
          Set layers of selection isolated (digs in compos and groups)
          Set layers of selection invisible (digs in compos and groups)
          Show layers by filter (add to visible layers)
          Isolate layers by filter (digs in compos and groups)
          Hide layers by filter (digs in compos and groups)
          Toggle display color by layer
          Match layer property of clicked object
          Create layer and control behavior
          Delete layer (digs in compos and groups)
          Lock layer
          Unlock layer
          Layers Management:
          Display a layers configuration status
          Save a layers state in the drawing
          Restore a layers state from the model
          Load a layers state from the drawing – Show only
          Load a layers state from the drawing – Append
          Update layers states
          Delete a layers state
          Save your layers states to an external file
          Load layers states from an external file
          French version soon to come.
          I'll be on holidays in Croatia β˜€ until Aug 19th so don't except quick bug fixes, but please leave your comments and bug reports here, I'll look at them when i'll be back.
          Best regards,
          ohze hehehe thank showmuch
            Tinygrasshopper
            Super Plugin!
            Vive Nancy!
            • utilerU Offline
              utiler
              Hi Didier, love this toolset!
              I have a request; see the attached screenshot and notes...
              Often I select components or groups to move to a new layer that is not there. 😳 Do you think you could add a line on the dialogue box to 'assign to selected' with the option of yes or no?
              This saves time deselecting, creating a new layer, selecting the groups again [which as you know can be tedious if you've carefully selected elements to move to a layer...] then accessing the layer drop down to move to the layer.
              Is it possible?
              cheers
              Just Curious...
                Didier Bur
                Hi Utiler,
                Try the attached rbs (replace your old one) and tell me if it works OK, before I incorporate it in a new release.
                Regards,
                layer_manager.zip
                DB
                • utilerU Offline
                  utiler
                  Thanks Didier, see comments in the screenshot:
                  Thanks for listening! if it can work it will make a whole lot of difference i can assure you!!
                  Cheers πŸ‘
                  Just Curious...
                    Didier Bur
                    Ooops 😳 Dropdowns were reversed...
                    Try this one instead.
                    layer_manager_corrected.zip
                    DB
                    • utilerU Offline
                      utiler
                      Thanks Didier, I thought that may be the case.... πŸ‘
                      It's almost right; see attached comments in attached and short screen video...
                      LayerManager-Fix.swf
                      Just Curious...
                        Didier Bur
                        The problem is that you cannot have (in a dialog box) dropdown lists that are not following each other, so the "NLN" field must be either on the first place or at the last place.
                        Attached is a fix that WORKS (this time i've tested it 😳 ).
                        Would you prefer the new layer name on top ?
                        Regards,
                        layer_manager_fix.zip
                        DB
                        • utilerU Offline
                          utiler
                          PERFECT!!!!!!
                          Thanks Didier, this is a massive time saver!!! Thank you so much!
                          Just Curious...
                          • utilerU Offline
                            utiler
                            Another little tweak that would save time.
                            As you can imagine, a file with multiple scenes is a pain to update all manually!!!!
                            Just Curious...
                              Didier Bur
                              I've added the new option you suggested (Needs to be more tested than I have).
                              "Visible in current scene only" is now the default in the dropdown list.
                              Regards.
                              layer_manager_corrected2.zip
                              DB
                              • JClementsJ Offline
                                JClements
                                Hi Didier:
                                Your layer manager toolbar is great.
                                Is there any chance of creating a single icon "mini" toolbar for just Toggling Color by Layer on and off?
                                Regards, John
                                • W Offline
                                  watkins
                                  Dear Didier,
                                  Will you be undating the download in the first posting of this topic? Your new version is hard to find in amongst all the requests and comments.
                                  Kind regards,
                                  Bob
                                    sorgesu
                                    Didier,
                                    I, and one of my students ( he is MAC I am PC) have had a problem with the Layer Manager.
                                    I have tried to download, unzip and reload the whole thing but there is no difference. None of the tools work at all.
                                    I have been reading through here and I downloaded the "fixed" layermanger.rb and accidently installed it directly in the PlugIns folder ... and then the Layer Mangager worked. The very first icon did not work but most of the others that I tried did work.
                                    When I realized that I had placed it in the wrong folder, I moved it into the Layer Manager folder, and then the toolbar stopped working again.
                                    I do have all the dependent rubies in the "Tools" folder so that is not the problem. Can you shed some light on what the problem might be? Many thanks. I am including reports from both the PC and the MAC from the Ruby console:
                                    PC:
                                    ["C:/Program Files (x86)/Google/Google SketchUp 8/Plugins", "C:/Program Files (x86)/Google/Google SketchUp 8/Tools", "C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ruby"]
                                    MAC:
                                    ["/Library/Application Support/Google SketchUp 8/SketchUp/Plugins", "/Library/Application Support/Google SketchUp 8/SketchUp/Tools", "/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ruby", "/Users/dougiecraig"]
                                    Susan Sorger
                                    • H Offline
                                      hpeng
                                      thank you~ for sharing this! 😎
                                        SUusrMk197x
                                        Dear Dider,
                                        Your layer manager is really great. πŸ‘
                                        I could't imagine sketching without it.
                                        The first time when I used your plugin I realized that some layers are not managed. After experencing with different versions of the plugin (V5, V6, V21) everything worked perfect for me. Though I was wondering why some symbols on the toolbar were twice available.
                                        Now when I set up Sketchup on a new machine I installed only the newest version (V21 isn't it?). On the virgin installation the troubles with some layers were back.
                                        After some new experencing I found out:
                                        Layers containing German letters (probably UNICODE?) in their name are not saved or restored.
                                        If "display layer config" is pressed the plugin shows that there are layers in the model which are not in the config. The same layers (but for each special character one caracter shorter) are listed in the saved layer config but not in model. (see attached screenshot)
                                        Now I've tested this on several different machines (2GHz Dualcore WinXP Pro, 2,2GHz Core2Duo WinXP Emb MU, 2,8GHz Core I-7 Win 7 Pro 32bit, 3,3GHz Xeon Win7 Pro 64). Everywere the same behavior.
                                        When I compared what was different to my very first setup I found out that the additional symbols came from the layer_manager_extension_v5.rb. In this combination the names of "German" layers are displayed shortened by the number of special characters too but saving and restoring commands (from version 21) work perfectly.
                                        Dear Dider. Please find this little annoying (German) bug and fix it.
                                        Best regards
                                          Didier Bur
                                          Yes this is a "unicode" bug. I've got the same behaviour with french letters like Γ©,Γ¨,Γ ,ΓΌ,Γͺ, and so on.
                                          I'll have a look at it when time permits.
                                          Regards,
                                          DB
                                            ByKAz
                                            Hello all,
                                            I have a question...
                                            Am I looking for a plugin to turn one major layer group or component with different layers and groups inside to one layer!?!?! I don't know if I did right the question...
                                            Like everything inside this major group or component (including sub-groups, lines, faces with different layers) will turn to one layer (major layer)
                                            I'm using the old version of LM_v6 and looks like don't have a way to do it. I don't know if this new version LM_v21 allow me to do that...
                                            • 2 / 3
