    [Plugin] Layer manager
    54 Posts 32 Posters 71.2k Views 32 Watching
      bararaboat
      In this version the layer Management & layer toolbar does not appear automatically.
      how can i make it appear automatically went program open? (su7 mac)
      Regard,
        diegog321
        Thank you very much for this plug in. Its been very useful.
        Diego
          Michaelv
          Regard,
          For the status of the toolbars to be registered (new sketchup opens with the last status (open or closed)) on Mac:
          Add these two ruby lines after their respective toolbar definition blocks in the original script:
          layertools_tb.restore
          layerconfigs_tb.restore
          • bagateloB Offline
            bagatelo
            Is there a tool that put the selected object in a new hidden / not hidden layer?
            • Didier BurD Offline
              Didier Bur
              @bagatelo: No... ๐Ÿ˜ž
              DB
              • H Offline
                haiarchi
                Can you set to Tool of sketchup to shortcut in sketchup
                  tulacong
                  @didier bur said:
                  Hi all,
                  Time to release the new version of my Layer Manager. Many new tools and enhancements, new toolbars.
                  Unzip in your Plugins folder. PDF doc included in the Layer Manager sub-folder.
                  [attachment=0:ea3yl9sk]<!-- ia0 -->lmtb.jpg<!-- ia0 -->[/attachment:ea3yl9sk]
                  Features list:
                  Tools:
                  Set layer of clicked object current
                  Set layer of clicked object current and isolated
                  Set layer of clicked object invisible
                  All layers visible
                  All layers invisible (except current)
                  Toggle visibility of all layers
                  Select/Deselect layer content
                  Move selection to current layer (digs in compos and groups)
                  Set layers of selection isolated (digs in compos and groups)
                  Set layers of selection invisible (digs in compos and groups)
                  Show layers by filter (add to visible layers)
                  Isolate layers by filter (digs in compos and groups)
                  Hide layers by filter (digs in compos and groups)
                  Toggle display color by layer
                  Match layer property of clicked object
                  Create layer and control behavior
                  Delete layer (digs in compos and groups)
                  Lock layer
                  Unlock layer
                  Layers Management:
                  Display a layers configuration status
                  Save a layers state in the drawing
                  Restore a layers state from the model
                  Load a layers state from the drawing โ€“ Show only
                  Load a layers state from the drawing โ€“ Append
                  Update layers states
                  Delete a layers state
                  Save your layers states to an external file
                  Load layers states from an external file
                  French version soon to come.
                  I'll be on holidays in Croatia โ˜€ until Aug 19th so don't except quick bug fixes, but please leave your comments and bug reports here, I'll look at them when i'll be back.
                  Best regards,
                  ohze hehehe thank showmuch
                    Tinygrasshopper
                    Super Plugin!
                    Vive Nancy!
                    • utilerU Offline
                      utiler
                      Hi Didier, love this toolset!
                      I have a request; see the attached screenshot and notes...
                      Often I select components or groups to move to a new layer that is not there. ๐Ÿ˜ณ Do you think you could add a line on the dialogue box to 'assign to selected' with the option of yes or no?
                      This saves time deselecting, creating a new layer, selecting the groups again [which as you know can be tedious if you've carefully selected elements to move to a layer...] then accessing the layer drop down to move to the layer.
                      Is it possible?
                      cheers
                      Just Curious...
                        Didier Bur
                        Hi Utiler,
                        Try the attached rbs (replace your old one) and tell me if it works OK, before I incorporate it in a new release.
                        Regards,
                        layer_manager.zip
                        DB
                        • utilerU Offline
                          utiler
                          Thanks Didier, see comments in the screenshot:
                          Thanks for listening! if it can work it will make a whole lot of difference i can assure you!!
                          Cheers ๐Ÿ‘
                          Just Curious...
                            Didier Bur
                            Ooops ๐Ÿ˜ณ Dropdowns were reversed...
                            Try this one instead.
                            layer_manager_corrected.zip
                            DB
                            • utilerU Offline
                              utiler
                              Thanks Didier, I thought that may be the case.... ๐Ÿ‘
                              It's almost right; see attached comments in attached and short screen video...
                              LayerManager-Fix.swf
                              Just Curious...
                                Didier Bur
                                The problem is that you cannot have (in a dialog box) dropdown lists that are not following each other, so the "NLN" field must be either on the first place or at the last place.
                                Attached is a fix that WORKS (this time i've tested it ๐Ÿ˜ณ ).
                                Would you prefer the new layer name on top ?
                                Regards,
                                layer_manager_fix.zip
                                DB
                                • utilerU Offline
                                  utiler
                                  PERFECT!!!!!!
                                  Thanks Didier, this is a massive time saver!!! Thank you so much!
                                  Just Curious...
                                  • utilerU Offline
                                    utiler
                                    Another little tweak that would save time.
                                    As you can imagine, a file with multiple scenes is a pain to update all manually!!!!
                                    Just Curious...
                                      Didier Bur
                                      I've added the new option you suggested (Needs to be more tested than I have).
                                      "Visible in current scene only" is now the default in the dropdown list.
                                      Regards.
                                      layer_manager_corrected2.zip
                                      DB
                                      • JClementsJ Offline
                                        JClements
                                        Hi Didier:
                                        Your layer manager toolbar is great.
                                        Is there any chance of creating a single icon "mini" toolbar for just Toggling Color by Layer on and off?
                                        Regards, John
                                        • W Offline
                                          watkins
                                          Dear Didier,
                                          Will you be undating the download in the first posting of this topic? Your new version is hard to find in amongst all the requests and comments.
                                          Kind regards,
                                          Bob
                                            sorgesu
                                            Didier,
                                            I, and one of my students ( he is MAC I am PC) have had a problem with the Layer Manager.
                                            I have tried to download, unzip and reload the whole thing but there is no difference. None of the tools work at all.
                                            I have been reading through here and I downloaded the "fixed" layermanger.rb and accidently installed it directly in the PlugIns folder ... and then the Layer Mangager worked. The very first icon did not work but most of the others that I tried did work.
                                            When I realized that I had placed it in the wrong folder, I moved it into the Layer Manager folder, and then the toolbar stopped working again.
                                            I do have all the dependent rubies in the "Tools" folder so that is not the problem. Can you shed some light on what the problem might be? Many thanks. I am including reports from both the PC and the MAC from the Ruby console:
                                            PC:
                                            ["C:/Program Files (x86)/Google/Google SketchUp 8/Plugins", "C:/Program Files (x86)/Google/Google SketchUp 8/Tools", "C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ruby"]
                                            MAC:
                                            ["/Library/Application Support/Google SketchUp 8/SketchUp/Plugins", "/Library/Application Support/Google SketchUp 8/SketchUp/Tools", "/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ruby", "/Users/dougiecraig"]
                                            Susan Sorger
                                            Former Seller Hand Rendered Entourage
                                            Former Canadian Authorized Training Centre, SketchUp
                                            • 2 / 3
