    [Plugin] Layer manager
    54 Posts 32 Posters 72.1k Views 32 Watching
    • T
      tulacong
      @didier bur said:
      Hi all,
      Time to release the new version of my Layer Manager. Many new tools and enhancements, new toolbars.
      Unzip in your Plugins folder. PDF doc included in the Layer Manager sub-folder.
      [attachment=0:ea3yl9sk]<!-- ia0 -->lmtb.jpg<!-- ia0 -->[/attachment:ea3yl9sk]
      Features list:
      Tools:
      Set layer of clicked object current
      Set layer of clicked object current and isolated
      Set layer of clicked object invisible
      All layers visible
      All layers invisible (except current)
      Toggle visibility of all layers
      Select/Deselect layer content
      Move selection to current layer (digs in compos and groups)
      Set layers of selection isolated (digs in compos and groups)
      Set layers of selection invisible (digs in compos and groups)
      Show layers by filter (add to visible layers)
      Isolate layers by filter (digs in compos and groups)
      Hide layers by filter (digs in compos and groups)
      Toggle display color by layer
      Match layer property of clicked object
      Create layer and control behavior
      Delete layer (digs in compos and groups)
      Lock layer
      Unlock layer
      Layers Management:
      Display a layers configuration status
      Save a layers state in the drawing
      Restore a layers state from the model
      Load a layers state from the drawing – Show only
      Load a layers state from the drawing – Append
      Update layers states
      Delete a layers state
      Save your layers states to an external file
      Load layers states from an external file
      French version soon to come.
      I'll be on holidays in Croatia β˜€ until Aug 19th so don't except quick bug fixes, but please leave your comments and bug reports here, I'll look at them when i'll be back.
      Best regards,
      ohze hehehe thank showmuch
      • T
        Tinygrasshopper
        Super Plugin!
        Vive Nancy!
        • utilerU
          utiler
          Hi Didier, love this toolset!
          I have a request; see the attached screenshot and notes...
          Often I select components or groups to move to a new layer that is not there. 😳 Do you think you could add a line on the dialogue box to 'assign to selected' with the option of yes or no?
          This saves time deselecting, creating a new layer, selecting the groups again [which as you know can be tedious if you've carefully selected elements to move to a layer...] then accessing the layer drop down to move to the layer.
          Is it possible?
          cheers
          Just Curious...
          • Didier BurD
            Didier Bur
            Hi Utiler,
            Try the attached rbs (replace your old one) and tell me if it works OK, before I incorporate it in a new release.
            Regards,
            layer_manager.zip
            DB
            • utilerU
              utiler
              Thanks Didier, see comments in the screenshot:
              Thanks for listening! if it can work it will make a whole lot of difference i can assure you!!
              Cheers πŸ‘
              Just Curious...
              • Didier BurD
                Didier Bur
                Ooops 😳 Dropdowns were reversed...
                Try this one instead.
                layer_manager_corrected.zip
                DB
                • utilerU
                  utiler
                  Thanks Didier, I thought that may be the case.... πŸ‘
                  It's almost right; see attached comments in attached and short screen video...
                  LayerManager-Fix.swf
                  Just Curious...
                  • Didier BurD
                    Didier Bur
                    The problem is that you cannot have (in a dialog box) dropdown lists that are not following each other, so the "NLN" field must be either on the first place or at the last place.
                    Attached is a fix that WORKS (this time i've tested it 😳 ).
                    Would you prefer the new layer name on top ?
                    Regards,
                    layer_manager_fix.zip
                    DB
                    • utilerU
                      utiler
                      PERFECT!!!!!!
                      Thanks Didier, this is a massive time saver!!! Thank you so much!
                      Just Curious...
                      • utilerU
                        utiler
                        Another little tweak that would save time.
                        As you can imagine, a file with multiple scenes is a pain to update all manually!!!!
                        Just Curious...
                        • Didier BurD
                          Didier Bur
                          I've added the new option you suggested (Needs to be more tested than I have).
                          "Visible in current scene only" is now the default in the dropdown list.
                          Regards.
                          layer_manager_corrected2.zip
                          DB
                          • JClementsJ
                            JClements
                            Hi Didier:
                            Your layer manager toolbar is great.
                            Is there any chance of creating a single icon "mini" toolbar for just Toggling Color by Layer on and off?
                            Regards, John
                            • W
                              watkins
                              Dear Didier,
                              Will you be undating the download in the first posting of this topic? Your new version is hard to find in amongst all the requests and comments.
                              Kind regards,
                              Bob
                                sorgesu
                                Didier,
                                I, and one of my students ( he is MAC I am PC) have had a problem with the Layer Manager.
                                I have tried to download, unzip and reload the whole thing but there is no difference. None of the tools work at all.
                                I have been reading through here and I downloaded the "fixed" layermanger.rb and accidently installed it directly in the PlugIns folder ... and then the Layer Mangager worked. The very first icon did not work but most of the others that I tried did work.
                                When I realized that I had placed it in the wrong folder, I moved it into the Layer Manager folder, and then the toolbar stopped working again.
                                I do have all the dependent rubies in the "Tools" folder so that is not the problem. Can you shed some light on what the problem might be? Many thanks. I am including reports from both the PC and the MAC from the Ruby console:
                                PC:
                                ["C:/Program Files (x86)/Google/Google SketchUp 8/Plugins", "C:/Program Files (x86)/Google/Google SketchUp 8/Tools", "C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ruby"]
                                MAC:
                                ["/Library/Application Support/Google SketchUp 8/SketchUp/Plugins", "/Library/Application Support/Google SketchUp 8/SketchUp/Tools", "/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ruby", "/Users/dougiecraig"]
                                Susan Sorger
                                Former Seller Hand Rendered Entourage
                                Former Canadian Authorized Training Centre, SketchUp
                                • H
                                  hpeng
                                  thank you~ for sharing this! 😎
                                    SUusrMk197x
                                    Dear Dider,
                                    Your layer manager is really great. πŸ‘
                                    I could't imagine sketching without it.
                                    The first time when I used your plugin I realized that some layers are not managed. After experencing with different versions of the plugin (V5, V6, V21) everything worked perfect for me. Though I was wondering why some symbols on the toolbar were twice available.
                                    Now when I set up Sketchup on a new machine I installed only the newest version (V21 isn't it?). On the virgin installation the troubles with some layers were back.
                                    After some new experencing I found out:
                                    Layers containing German letters (probably UNICODE?) in their name are not saved or restored.
                                    If "display layer config" is pressed the plugin shows that there are layers in the model which are not in the config. The same layers (but for each special character one caracter shorter) are listed in the saved layer config but not in model. (see attached screenshot)
                                    Now I've tested this on several different machines (2GHz Dualcore WinXP Pro, 2,2GHz Core2Duo WinXP Emb MU, 2,8GHz Core I-7 Win 7 Pro 32bit, 3,3GHz Xeon Win7 Pro 64). Everywere the same behavior.
                                    When I compared what was different to my very first setup I found out that the additional symbols came from the layer_manager_extension_v5.rb. In this combination the names of "German" layers are displayed shortened by the number of special characters too but saving and restoring commands (from version 21) work perfectly.
                                    Dear Dider. Please find this little annoying (German) bug and fix it.
                                    Best regards
                                    • Didier BurD
                                      Didier Bur
                                      Yes this is a "unicode" bug. I've got the same behaviour with french letters like Γ©,Γ¨,Γ ,ΓΌ,Γͺ, and so on.
                                      I'll have a look at it when time permits.
                                      Regards,
                                      DB
                                      • B
                                        ByKAz
                                        Hello all,
                                        I have a question...
                                        Am I looking for a plugin to turn one major layer group or component with different layers and groups inside to one layer!?!?! I don't know if I did right the question...
                                        Like everything inside this major group or component (including sub-groups, lines, faces with different layers) will turn to one layer (major layer)
                                        I'm using the old version of LM_v6 and looks like don't have a way to do it. I don't know if this new version LM_v21 allow me to do that...
                                          seasdes
                                          Can I save more than one layer state. I am asked what layer state I want to over right when I try to save a new layer state. I do not get an option not to over right a layer state.
                                          Nice tools.
                                          Walter
                                          Using Sketchup Pro 2019
                                          • Didier BurD
                                            Didier Bur
                                            @seasdes:
                                            Yes, you can save as many layer states as you want.
                                            Try to overwrite any of your previously saved layer state and see if it is still there.
                                            I guess this is a bug but the layer state you overwrite will not be overwritten.
                                            Regards,
                                            DB
                                            • 2 / 3
