    Cross hatch wall lines
    7 Posts 5 Posters 4.0k Views 5 Watching
    • Al HartA
      Al Hart
      Hi ,
      I ve a Question,
      if I make a Wall from A house and
      look above the plan in my computer
      is there a Possibility to have in the
      Materials in Sketch up with 45 degree
      lines which are not like a wave.
      I need through lines for my plan
      I think you may be able to have all the lines in the same direction if you place all the walls in a group, and then apply the material to a group.
      Here is a result with a line pattern on individual walls.
      (The pattern rotates with the wall)
      Here is a result, obtained by placing all the walls in a group before setting the material to the group
      (The pattern is consistent for the entire model)
      [Image Removed - I thought the grouping had worked, but it didn't. - See later post]
      Is this what you were looking for?
      If not, can you send a sample image of what you get now and what you want
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
      • Chris FullmerC
        Hi Al, wondering if you posted the wrong images, as they are identical. Doesn't look like anything was fixed?
        Chris
        All my Plugins I've written
        • Mike LuceyM
          Mike Lucey
          Hi Guys,
          I've thought about this 'problem' many times. The 45 degree cross-hatch has been traditionally used in manual drafting and still is. The reason for the 45 degree cross hatch was 'simply' to indicate a material.
          With the use of a digital application like SketchUp it really does not make much sense using a 45 degree cross-hatch when one can actually show the material in question, concrete, metal, wood etc etc
          Okay, I realise that this may not be the 'standard' but it is also very easy to show a legend on the drawing showing each of the materials being used.
          Mike
          • Al HartA
            Al Hart
            Chris
            Oops - Actuallu the two images were the same - putting the walls into a group didn't fix it.
            In my original model each wall was a group already. By exploding the walls, I was able to get the result I wanted. (assuming that this was what someone wanted)
            Al Hart
            • Al HartA
              Al Hart
              As I read the first query, I see that he is complaining about wavy lines.
              Maybe he just needed a 45 degree pattern with straight lines.
              I send him this thread, hopefully he will add some comments.
              Al Hart
              • charly2008C
                charly2008
                Hi Al,
                could this be a solution. I took a texture with 45 degree line and scaled it down.
                Karlheinz
                • R
                  richcat
                  Link to thread on Hatch lines with links to hatch skm files etc - might help.
