    Set standard segments in a arc or circle
    7 Posts 5 Posters 6.5k Views 5 Watching
    • D
      dennis013
      I use sketchup for modelling electronic casings. The sketchup drawings are then printed with a dimension 3d printer as a prototype.
      Mostly i use round corners but 8 segments is too blocky. A nice feature would to configure the amounts of segments.
        As soon as you click the icon Circle or Arc Circle, before drawing type on the numeric key board numbers of segments wished πŸ˜‰
        • GaieusG
          After you defined the segment count for a circle or arc (or actually, also a polygon), SU will "remember" and "stick" to it in that session (until you change it again, of course). So it's not as bad as it looks first (although setting the default segment number in the Preferences or Model info would even be better).
          • M
            MartinRinehart
            To specify 12 segments type "12s". (If you just type "12", SU thinks that's the radius.)
            Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
            • T
              tomsdesk
              Even when I first set the segments up to what I want, importing a cad file always comes in at the lower default...this I would love to change!
              2.5D Trees & Shrubs!
                Of course don't this one by TIG! 😎
                ArcCurve-set_segments.rb
                For set Circles and arc circle after Importation or after drawing! β˜€
                • T
                  tomsdesk
                  You know...after logging off and setting down to dinner it hit me that there must be a ruby for this. Thanks Frenchy!
