    Indigo Error
    extensions
    7 Posts 2 Posters 1.1k Views 2 Watching
      Here's the error
      Error: SceneLoaderExcep: ModelLoadingStreamHandlerExcep: UV set with index 1 was exposed, but the UV set data was not provided. (In element 'mesh', around line 6, column 9)
      Does anyone have experience of this?
      I read on Indigo Forums about UV Settings but i only installed it today as i'm trying it out and have no experience with the UI? 😲
      • R
        remus
        Which version of skindigo/indigo are you using? and what are you doing to cause the error?
          Indigo Renderer v2.0.10
          SkIndigo 1.0.9 Released May 10 2008
          Rendering the following
          Sun Room Interior.skp
          Then error occurs, i'm sure it's my fault.
          • R
            remus
            First thing to do is upgrade to skindigo 2.0.10, it wont work otherwise.
              I downloaded straight from the indigo site?
              http://www.indigorenderer.com/documentation/sketchup/
              Is that not latest? Do you have a link to a newer version
              • R
                remus
                Here you go: http://www.indigorenderer.com/forum/viewtopic.php?f=17&t=6403
                Even comes with its own installer πŸ‘
                  Sorted, thanks Remus
