    Frustrating Paint problem
    5 Posts 2 Posters 543 Views 2 Watching
    • M
      mogogirl
      I am trying to paint an object I have and several faces won't paint. If I hit the shift and do the whole thing at once the paint goes onto all faces. But I don't want to do that. I want to paint only certain faces and when I click on them absolutely nothing happens. It doesn't matter what paint material I use.
      Any ideas why only certain faces of an object will fill in and not others?
      Thanks!
      • massimoM
        massimo Moderator
        Maybe the faces are all grouped? If so double click on the group or the component and then you can paint a single face.
        • M
          mogogirl
          I have exploded the figure so nothing is grouped. The back of a cube I made will NOT paint as well as a couple of other surfaces... I just don't understand.
          • massimoM
            massimo Moderator
            Could you post the model?
            • M
              mogogirl
              I got it, thanks. I just worked backwards from your suggestion and re-grouped everthing and then double-clicked and painted individual surfaces. It's working now. THANKS!
