    [Plugin] SectionCutFace
    569 Posts 171 Posters 540.9k Views 170 Watching
    • B
      Bob_CP
      I've used this for years on multiple versions of SU. All of a sudden, it crashes SU 2023 Pro. Yesterday it worked, today it's causing SU to hang
      • TIGT
        Everything you have set up looks correct.
        Try reverting to an earlier version.
        It has changed from RBS to RBE filetypes which might be causing the heartache...
        SectionCutFace_v6.2.rbz
        • A
          alskaro
          Hello! Love this extension thank you ! Do you think it would be possible to be able to change the fill individually after the cut ? (like when you cut trough multiple materials) or simply having a color style that would color the face in the same material as the cut object ? That would be dope, especially with the 2025 "patterns" material!
          Thank you ! Have a nice day ! πŸ™‚
          TIGT Dave RD 2 Replies Last reply
          • TIGT
            TIG Moderator @alskaro
            @alskaro
            You can already do that to a section cut face group.
            Unlock it [if needed], then edit the group, and apply the different materials you want to the faces.
            If you regenerate the section cut face then those changes are lost.
              Dave R @alskaro
              @alskaro do you mean something like this? As TIG says, apply whatever materials you want to the various faces in the SectionCut Face.
              • I
                IDK
                Good day,
                would it be possible to have the last version that works with SketchUp 8? Thank you very much!
                • TIGT
                  @idk
                  Our archived old copies are not perfect - try this v2.6 it should work with older SketchUp versions like v8, but has it none of the abilities of the current v8.0.
                  SectionCutFace.rb
                  There's also this intermediate version which might still work ?
                  • I
                    IDK
                    Thank you very much
                    • I
                      IDK
                      The v2.6 work fine TY, no the 6.2.
                      All solved. TYVM!
                      • 25
                      • 26
                      • 27
                      • 28
                      • 29
                      • 29 / 29
