    [Plugin][$] RoundCorner - v3.4a - 31 Mar 24
    1.5k Posts 477 Posters 4.1m Views 477 Watching
      taktakplz
      hi fredo
      the round corner is not working on my su13 but the curviloft and tools on surface is working fine.
      where i can install the higher version of libfredo6?i install it using extension warehouse
        It's clearly spelled out for you in the first post on the first page of this thread.
        Which takes you to the first post on the first page of the LibFredo6 thread which has the link you need.
        Get the SCF Plugin Store tool and use it to auto install your plugins.
          taktakplz
          @fredo6 said:
          @mattiab said:
          SketchUp crashes each time i try to use this plugin, do you know why?
          Do you have an old version of Vray?
          fredo i do have the same problem
          i have installed V-Ray for SketchUp v1.60.22
            Remove VRay for SketchUp. It is has been known to cause problems with other plugins. Or at least use the current version of it. The current version appears to be 2.0.
              taktakplz
              thanks for the help fredo
              • cottyC Offline
                cotty
                Dave!?
                my SketchUp gallery
                  littleche
                  oundCorner cannot do anything for this model, because it is triangulated.
                  The method is to use Subdivision, which you may possibly try with Artisan by Whaat.
                  Fredo
                  thank you fredo for your help .
                  I thought this work is Possible whit your plugin .
                  I hope this Reliability Be included in future versions. 😛
                  • G Offline
                    goblinteasemaid
                    very nice tool, works on SU6
                    doesnt do groups so you need to group edit or explode
                    and you only get one chance for offset input. Get it wrong and you must revert to sharp edge start - obvious really, no big deal
                    think of the time spent doing it manually YUK
                    thanx mille foix
                    Goblint
                    • G Offline
                      goblinteasemaid
                      F6 one thing I forgot to mention, I have an annoying issue with the drop down window in Round corners, its squashed up.
                      window problem
                        marcostakahasi
                        i'm trying to install. where's the archive?
                          It's very clearly spelled out in the first post on the first page of this thread.
                          Don't forget to read and follow the rest of the directions.
                          • fredo6F Offline
                            fredo6
                            Installation of my Plugins is now done via the SCF Plugin Store.
                            Fredo
                            • fredo6F Offline
                              fredo6
                              You must have a screen with high resolution, analog to Retina screens on Mac.
                              Nothing to do, because this dépends on Sketchup and these problem of high résolutions screen are not fixed yet.
                              Possibly you can select the option "Retina screen" in the Default parameters of LibFredo6, but the correction is not guaranteed (see this thread).
                              Fredo
                              • G Offline
                                gruzdev_f
                                Install all the instructions.
                                but what is it?
                                • TIGT Online
                                  If you read the tool's installation guidance it explains that, as with most of Fredo's tools, it need a set of helper files installed too - 'LibFredo6'
                                  You can get that from the PluginStore...
                                  http://sketchucation.com/pluginstore?pln=LibFredo6
                                  Install it, then restart SketchUp to ensure everything gets reintegrated...
                                  • G Offline
                                    gruzdev_f
                                    As you can see in the screenshot, LibFredo6 installed but sketchup not see him.
                                    LibFredo6 folder is where it is necessary
                                    • TIGT Online
                                      Sorry, I now see the problem.
                                      You have a 'Cyrillic name'.
                                      In v2014 FILE can return incorrectly if there are no ASCII characters in the Plugins folder's path, at least without further 'trapping' of errors.
                                      I though Fredo has addressed the issue recently, when he updated his Lib and all of his tools.
                                      Have you installed the very latest versions of all of Fredo's tools AND Lib from the PluginStore... ?
                                      If so... if you make a Windows User account with an ASCII name [like "Fedos" ?] does it work ?
                                        SketchMax
                                        Hello Sketchupers!
                                        First post here for me ever, I'm currently working as a 3d-modeler for a company in Sweden and I've been on it for soon 2½ months.
                                        With that said I've tried to learn everything by myself now for 2½ months, so I'm still quite new to sketchup.
                                        But I finally have come to some struggle and i tried to look around for solutions, but unsuccessful unfortunately.
                                        My problem is that I got a dome-shaped object which is not entirely domy(Jokes aside) and I need the sloped side to the top to be more round without having to raise the top a few MM just to round the top of that(which also does not change the fact it won't look right).
                                        I'll insert a picture for better understanding my situation(I hope).
                                        http://i.imgur.com/kqcLh2j.png
                                        The reason I post here is because I'm not to familiar with forums and such,
                                        and for that I use your "Round Corners" ALOT! Kudos to that plugin.
                                        I'm also sorry if I posted in the wrong forum.
                                        I hope I didn't make this to complicated for you guys to understand and I thank you in advance.
                                        //Max
                                          snapster42
                                          Roundcorner is a very useful plugin. But I am having some trouble using it for my purpose. I am trying to create a model for 3D printing, and one of the design requirements is that sharp edges should be avoided. Another requirement, however, is that the object must be a "water-tight" solid in the end, and I am having trouble satisfying that with roundcorner. For example, if I try to round the corners on something like this:
                                          The plugin appears to work, but when I group it, it doesn't become a solid. I use the "solid inspector" plugin to see what's wrong, and it shows me this:
                                          When I zoom in to this, I can't see any problem:
                                          Has anyone encountered this type of problem, and found a solution?
                                          • cottyC Offline
                                            cotty
                                            RoundCorner sometimes creates additional faces, in your case there is an internal face created and after you deleted this face, the object will get solid.
                                            my SketchUp gallery
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 74
                                            • 75
                                            • 47 / 75
