    Modeling topography + roads
    5 Posts 3 Posters 787 Views 3 Watching
    • R
      Ross_K
      Hi!
      I'm trying to model a small town in sketchup. I'm using the sandbox tool to create the terrain from contours positioned at the correct elevation. What I can't figure out is how to do the roads! How do I draw them? They have to slope with the terrain, but how do I draw on such a surface when it's interpolated from the contours? I would like to be able to attach a different material to the roads and I need them sloping exactly as the terrain does, I basically need to be able to draw on my terrain... any ideas on how to achieve this? Different methods you have used in the past?
      Many thanks!
      RK
      http://www.rk-studios.ca
      • P
        perk
        If you already have the roads drawn in cad you can import them and drape them onto the terrain surface.
          check this out
          http://forums.sketchucation.com/viewtopic.php?f=18&t=19522
          hope it helps and i'm sure there are even more tutorials around than this
          • R
            Ross_K
            wow thanks for the quick response guys! That was exactly wht I was looking for!
            I have another quick question... How can I project an aerial photo onto this terrain?
            Thanks a ton!
            RK
              hello again,
              watch this video from 'The SketchUp Show'
              It might help
              http://www.go-2-school.com/media/view/1
