    [Searched]I'm searching for some plugins.
    5 Posts 5 Posters 556 Views 5 Watching
    • R
      Remi-X
      I don't know if this is the good forum, but I'll post:
      I'm searching for some plugins:
      -SDS,
      -Joint Push and Pull,
      -Skin Tool.
      This are the names that Elisei noted on his tutorial, but I only found the Offset tool on Smustard. Where can I find the others?
      P.S. maybe you found some spelling faults in my text, because my English isn't very good...
      • GaieusG
        Hi Remi (hm... and Massimo, as you beat me πŸ˜‰ ),
        The best place to start searching is the Extensions Index" (actually outside the forum already).
        • Subdivide And Smooth (this will eventually take you to Smustard and cost you $ 20 if you want to buy it)
        • Joint Push Pull - Visual Edition
        • skin22
        • ely862meE
          ely862me
          Hi Remi-X. I m glad u joined us.As u can see there are the plugins .
          Hope u ll find more than some plugins here πŸ˜‰
          Cheers!
          Elisei
          Elisei (sketchupper)
          Come and See EliseiDesign
          • massimoM
            massimo Moderator
            -"Subdivide and smooth" you can buy it at Smustard:
            • "Joint push pull" is here http://forums.sketchucation.com/viewtopic.php?f=180&t=6708&st=0&sk=t&sd=a&hilit=joint+push+pull;
            • "Skin" is here http://forums.sketchucation.com/viewtopic.php?f=180&t=1306&st=0&sk=t&sd=a&hilit=skin+plugin.
              You can use this http://www.sketchucation.com/extensions-index/ for plugins search.
              Seems the place there are the must and more free plugins is here Ruby Librairy Depot β˜€
              by Didier Bur πŸ˜‰
