    How do I place components on a face?
    6 Posts 3 Posters 963 Views 3 Watching
    • K Offline
      Khai
      first the model I'm working on -
      http://farm4.static.flickr.com/3201/2738256377_ab04f8f13a_o.jpg
      a concept Steampunk TARDIS - this is in trueSpace 4.3. I'm now splitting my modeling between tS and SU.. (SU is just so easy to work in..)
      now I'm going to be using SU to snap the pipes into place as I build the Root of the Console out. now, each pipe section has a set of bolts on the flange.
      I thought I could make the bolt as a component then place that onto the flange... and thats where I'm falling over.
      first, anyone know any good tutorials for making / using components and then placing the bolt onto a face, whats the best way to line it up with the face? (is there say a ruby to paint components onto mesh?)
        When you create a component, have a look in the window that appear. You can set it to glue to horizontal, vertical or any face.
        • K Offline
          Khai
          will that work on any face?
          the bolts are gonna be all over the place... (my aim is to model every detail.. every nut, bolt and screw...)
            Shortly; yes.
            BUT only on (single) faces. Not on components/groups (so you need to edit them first) and not on curved surfaces (if you turn on hidden geometry however, they work on the unhidden facets).
            • K Offline
              Khai
              grin
              thanks guys πŸ˜„
              sorry for all the questions (and trust me there's more coming)
                Keep asking.
                Just keep posting the progress of your work. πŸ˜‰
