    Move groups with different measures?
    55 Posts 4 Posters 33.5k Views 4 Watching
      So i must use the Tig Advertissement more soon than I have expected ๐Ÿ’š
        This group.bounds.min.z. can be found somewhere or the sorting of Groups must be forged again?
        (nothing about sort, sorting in the API helping) ๐Ÿ˜ฎ
        • thomthomT
          Build a hash with the entities as the key and their Z posiiton as value and then sort the hash by the values.
            Each groups has not a "time creation" trace board? So no need to remake a sorting ?
            Seems I have re-open a new nightmare door ๐Ÿ’š
            • Chris FullmerC
              Awesome Pilou! Keep it up, its looking great. You've got lots of good help around here.
              Chris
              All my Plugins I've written
              • TIGT
                Try something like...
                zeds=[]
                index=0
                groups.each{|group|
                   zeds.push(group.bounds.min.z, index)
                   index+=1
                zeds.sort!
                sorted_groups=[]
                zeds.each{|z|sorted_groups.push(groups[z[1]]) }
                ### sorted_groups is now groups sorted by Z
                  Does the group.bounds.min.z only valuable in SU 7?
                  Edit seems not ๐Ÿ˜„
                  little try but seems I miss something ๐Ÿ˜„ (any doubt selection but the sorted_groups gives nothing on the screen)
                  model = Sketchup.active_model
                  entities = model.entities
                  selection = model.selection
                  groups = []
                  z=0
                  zeds=[]
                  index=0
                  groups.each{|group|
                     index+=1
                  zeds.sort!
                  sorted_groups=[]
                  sorted_groups.each do |e|
                    point = Geom;;Point3d.new 0,0,z
                    t = Geom;;Transformation.new point
                    e.transform!(t)
                    z =  z + 1000.mm
                    it's like a snowball on the top of the mountain ๐Ÿ˜„
                    http://www.id2sorties.com/id2photos/5907205456neig.jpg
                    • TIGT
                      groups = [] then nothing set !!!
                      You emptied the groups array...
                      You need to fill it from the selection... ๐Ÿค“
                      groups=[];selection.each{|entity|groups.push(entity) if entity.kind_of?(Sketchup;;Group)}
                        another try found: undefined method โ€˜[]โ€™ ๐Ÿ˜•
                        z=0
                        zeds=[]
                        index=0
                        sorted_groups=[]
                        groups.each{|group|zeds.push(group.bounds.min.z, index)
                           index+=1
                        zeds.sort!
                        sorted_groups.each do |e| # update!
                          # Now we process the groups
                          # Apply the transformation
                          e.transform!(t)
                          z = z + 100.cm
                        • thomthomT
                          Is that the only error message you get?
                          You're hooked now! No way back! ๐Ÿ˜‰ ๐Ÿ˜„
                          • TIGT
                            Here's some tweaked code
                            def test()
                              model.start_operation("Move in Z")
                                zeds=[]
                                index=0
                                sorted_groups=[]
                                groups.each{|group|zeds.push([group.bounds.min.z, index])
                                   index+=1
                                zeds.sort!
                                z = 0.0
                                  t = Geom;;Transformation.new(Geom;;Point3d.new(0,0,z))
                                  e.transform!(t)
                                  z = z + 100.cm
                              model.commit_operation
                              return nil
                            end#def
                            Runs as ' test'.
                            I made a typo - it needed an array [] of two items adding to zeds: zeds.push([group.bounds.min.z, index]) not two 'loose' items as in zeds.push(group.bounds.min.z, index).
                            I made your z = 0 into z = 0.0 as it needs the number as a float, not an integer...
                            Removed 'point' variable and set the point definition directly inside the transformation - not necessary but fewer variables...
                            I added a model.start_operation("")...model.commit_operation so it becomes a one step undo.
                            I added return nil at end so the Ruby-Console doesn't get clogged with info...
                            Tested it - it works...
                              Seems indeed that some corrections were necessary ๐Ÿ˜„
                              This time works like a charm! Excellent! TIG + Thomthom! Bravo! ๐Ÿ˜Ž
                              I will see all that more in detail for learn this little cryptic language ! โ˜€
                              Very funny plug! ๐Ÿ˜‰
                              For the next Pilou's foolish... ๐Ÿ’š
                              ...I need to know the "centroรฏd" (xyz) of a "bounding box's group"
                              Here of course without different measure, just for little test! ๐Ÿ˜„ (click image)
                              • TIGT
                                centre_point=group.bounds.center
                                See http://code.google.com/apis/sketchup/docs/ for all these details ๐Ÿ˜‰
                                  Thx I had missed this one ๐Ÿ˜‰
                                  • thomthomT
                                    It'd help if you posted the error messages.
                                    However, I can still see the problem here. Sketchup::Component isn't an SU object. Check the manual, you have Sketchup::ComponentDefinition and Sketchup::ComponentInstance. In your case you're looking for a Sketchup::ComponentInstance.
                                      I have replaced "Group" by "Component" but seems that is not so simple ๐Ÿ’š
                                      groups=[];selection.each{|entity|groups.push(entity) if entity.kind_of?(Sketchup;;Component)}
                                          groups.each{|component|zeds.push([component.bounds.min.z, index])
                                      Else I can yet nest a component inside a group color transparent ๐Ÿ’š
                                      That works fine (just disable Edges visible) but I suppose there is another thing ๐Ÿ˜„
                                        @ Tig Some cryptic but I will see that ๐Ÿ˜‰
                                        Joint an image for no ambiguities
                                        So here the increment is 300 cm
                                        Edit sorry I have not seen all these speedy results! ๐Ÿ˜ณ
                                        @Thomthom! Yes that is that ! e.transform!(t) ๐Ÿ˜‰
                                          Come back in these very dangerous territories ๐Ÿ’š
                                          As I understand that retrieve the center XYZ of the bounding box group by
                                           center = boundbox.center
                                          but how give these 3 values(?) to these 3 variables ? ๐Ÿ˜’
                                          xc= ?
                                          yc= ?
                                          zc= ?
                                          must be trivial but yet some foggy for me ๐Ÿ˜„
                                          PS I read the API from the end to the start, and inverse but this stay mysterious found anything except that ๐Ÿ’š
                                          • thomthomT
                                            boundbox.center returns an object of type Point3d. You can check what an object is by checking the .class value of an object. That gives you an indication to where to look.
                                            xc= boundbox.center.x
                                            yc= boundbox.center.y
                                            zc= boundbox.center.z
                                            • 2 / 3
