    Move groups with different measures?
    55 Posts 4 Posters 34.8k Views 4 Watching
      groups = [] then nothing set !!!
      You emptied the groups array...
      You need to fill it from the selection... ๐Ÿค“
      groups=[];selection.each{|entity|groups.push(entity) if entity.kind_of?(Sketchup;;Group)}
        another try found: undefined method โ€˜[]โ€™ ๐Ÿ˜•
        model = Sketchup.active_model
        entities = model.entities
        selection = model.selection
        z=0
        zeds=[]
        index=0
        sorted_groups=[]
        groups.each{|group|zeds.push(group.bounds.min.z, index)
           index+=1
        zeds.sort!
        zeds.each{|z|sorted_groups.push(groups[z[1]]) }
        ### sorted_groups is now groups sorted by
        sorted_groups.each do |e| # update!
          # Now we process the groups
          point = Geom;;Point3d.new 0,0,z
          t = Geom;;Transformation.new point
          # Apply the transformation
          e.transform!(t)
          z = z + 100.cm
          Is that the only error message you get?
          it's like a snowball on the top of the mountain ๐Ÿ˜„
          You're hooked now! No way back! ๐Ÿ˜‰ ๐Ÿ˜„
            Here's some tweaked code
            def test()
              model.start_operation("Move in Z")
                zeds=[]
                index=0
                sorted_groups=[]
                groups.each{|group|zeds.push([group.bounds.min.z, index])
                   index+=1
                zeds.sort!
                z = 0.0
                  t = Geom;;Transformation.new(Geom;;Point3d.new(0,0,z))
                  e.transform!(t)
                  z = z + 100.cm
              model.commit_operation
              return nil
            end#def
            Runs as ' test'.
            I made a typo - it needed an array [] of two items adding to zeds: zeds.push([group.bounds.min.z, index]) not two 'loose' items as in zeds.push(group.bounds.min.z, index).
            I made your z = 0 into z = 0.0 as it needs the number as a float, not an integer...
            Removed 'point' variable and set the point definition directly inside the transformation - not necessary but fewer variables...
            I added a model.start_operation("")...model.commit_operation so it becomes a one step undo.
            I added return nil at end so the Ruby-Console doesn't get clogged with info...
            Tested it - it works...
              Seems indeed that some corrections were necessary ๐Ÿ˜„
              This time works like a charm! Excellent! TIG + Thomthom! Bravo! ๐Ÿ˜Ž
              I will see all that more in detail for learn this little cryptic language ! โ˜€
              Very funny plug! ๐Ÿ˜‰
              For the next Pilou's foolish... ๐Ÿ’š
              ...I need to know the "centroรฏd" (xyz) of a "bounding box's group"
              Here of course without different measure, just for little test! ๐Ÿ˜„ (click image)
                centre_point=group.bounds.center
                See http://code.google.com/apis/sketchup/docs/ for all these details ๐Ÿ˜‰
                  Thx I had missed this one ๐Ÿ˜‰
                    It'd help if you posted the error messages.
                    However, I can still see the problem here. Sketchup::Component isn't an SU object. Check the manual, you have Sketchup::ComponentDefinition and Sketchup::ComponentInstance. In your case you're looking for a Sketchup::ComponentInstance.
                      I have replaced "Group" by "Component" but seems that is not so simple ๐Ÿ’š
                      groups=[];selection.each{|entity|groups.push(entity) if entity.kind_of?(Sketchup;;Component)}
                          groups.each{|component|zeds.push([component.bounds.min.z, index])
                      Else I can yet nest a component inside a group color transparent ๐Ÿ’š
                      That works fine (just disable Edges visible) but I suppose there is another thing ๐Ÿ˜„
                        @ Tig Some cryptic but I will see that ๐Ÿ˜‰
                        Joint an image for no ambiguities
                        So here the increment is 300 cm
                        Edit sorry I have not seen all these speedy results! ๐Ÿ˜ณ
                        @Thomthom! Yes that is that ! e.transform!(t) ๐Ÿ˜‰
                          Come back in these very dangerous territories ๐Ÿ’š
                          As I understand that retrieve the center XYZ of the bounding box group by
                           center = boundbox.center
                          but how give these 3 values(?) to these 3 variables ? ๐Ÿ˜’
                          xc= ?
                          yc= ?
                          zc= ?
                          must be trivial but yet some foggy for me ๐Ÿ˜„
                          PS I read the API from the end to the start, and inverse but this stay mysterious found anything except that ๐Ÿ’š
                            boundbox.center returns an object of type Point3d. You can check what an object is by checking the .class value of an object. That gives you an indication to where to look.
                            xc= boundbox.center.x
                            yc= boundbox.center.y
                            zc= boundbox.center.z
                              Many thx! โ˜€
                              It's always the more easy ans usefull who is not written as example ๐Ÿ˜’
                                ??? = error : in โ€˜initializeโ€™: undefined local variable or method โ€˜boundboxโ€™ ๐Ÿ˜ฎ
                                #groups = []
                                xp=100  # Pivot Point
                                yp=100
                                zp=100
                                xc=0  #Center Point of the grouped object
                                yc=0
                                zc=0
                                xe=0  #End Point of the grouped object
                                ye=0
                                ye=0
                                selection.each do |e| # update!
                                  # Skip all entities that aren't groups
                                  next unless e.is_a? Sketchup;;Group
                                        xc= boundbox.center.x # ??? error
                                xe=xc
                                ye=yc
                                ze=zc
                                if xc<xp
                                xe =xc - 100
                                  if xc>xp
                                xe =xc +100
                                if yc<yp
                                ye =yc - 100
                                  if yc>yp
                                ye =yc +100
                                if zc<zp
                                ze =zc - 100
                                  if zc>zp
                                ze =zc +100
                                  point = Geom;;Point3d.new xe,ye,ze
                                  e.transform!(t)
                                  That's because of center = boundbox.center <- you haven't referenced boundbox yet.
                                  change to
                                  center = e.bounds.center
                                     xc= center.x
                                     yc= center.y
                                     zc= center.z
                                    Thx! โ˜€
                                    More easy with that ๐Ÿ˜„ Works like a charm ๐Ÿ˜Ž
                                    I can now test some natures of explodes ๐Ÿ’š
                                      Funny thing ๐Ÿ˜„
                                        Looking good Pilou!
                                        Instant assembly drawings! ๐Ÿ˜„ This should come in handy.
                                          Instant assembly
                                          Alas for the inverse, that must be more tricky! ๐Ÿ˜•
                                          Better is use the Undo ๐Ÿ’š
                                            hm... You could store the relative position you move the entities by in and attribute dictionary. Then perform the opposite when you want to reassemble.
                                            though, that will fail if the user moves anything...
                                            Maybe, you could store the original absolute position before you move stuff. Then you can reassemble back to that original position. That would allow the user to move things around as they please.
                                            • 2 / 3
