    [Plugin] Select Outer Edges v1.0
    12 Posts 10 Posters 21.4k Views 10 Watching
    • Chris FullmerC Offline
      This is pretty simple, from a request from John Clements here:
      http://forums.sketchucation.com/viewtopic.php?f=180&t=20267&p=168997&sid=195d6184b32fa0a6257f3883cb07a9f6#p168940
      Select a group of faces and edges and run this plugin. It will select only the outer edges (perimeter edges) and also edges that border an interior hole. It only selects edges that you have selected before running the script. So hidden edges will not get added to the outer edges selection if they are not selected. Use the triple click selection method to make sure that hiiden edges are selected correctly. Also, single lines are not added to the selection either. Here is a video that sort of shows all of that. I hope it makes sense, and is helpful. Video (no sound):
      [flash=564,503:3kvcrnb0]http://www.chrisfullmer.com/forums/select_outer_edges.swf[/flash:3kvcrnb0]
      Chris
      PS this is a script I probably wont be updating or adding to. Maybe it should just be included in Thom's selection toys (maybe it already is?). So if its in another, more major script out there, you might just be best using that one. And if someone points me to it, I'll probably just remove this script and point people to the better script.
      clf_select_outer_edges.rb
      All my Plugins I've written
      • boofredlayB Offline
        boofredlay
        I could have used this last weekend when I made this:
        http://www.formfonts.com/requestFile.php?type=1&id=12463&img=FF_Model_ID12463_1_A1_A2.jpg
        Thanks Chris, works great.
          Thanks Chris.
          Eric, you going to build that?
            boofredlay
            I already did, in SU, for FF πŸ˜‰
            http://www.formfonts.com/viewModel.php?view=1&id=12463&config=1
            Build it physically... nope.
              simdidengelecege
              Thank you very much for this plug-in...
              It is so functional.
              • U Offline
                urs0815
                Thank you Chris, this is a very useful plugin! πŸ‘
                • P Offline
                  Panga
                  Thanks a lot for this simple but very usefull script !! Good work.
                  • 3 Offline
                    3dbuilder
                    Hey Google:
                    Hire. Chris. Fullmer.
                    And if they don't hire you Chris, you should apply for a position with Bonzai 3D.
                    Thanks for all your plug-ins. Whenever I need to be productive and find basic functionality like this that isn't in Sketchup, I just Google "Chris Fullmer tool"
                    Thanks again.
                      @3dbuilder said:
                      Hey Google:
                      Sounds like a good plan to me since I just got furloughed today, from a job that already paid too liitle πŸ˜„
                      Chris
                      Glad you like the script!
                      • JClementsJ Offline
                        JClements
                        Bummer, Chris.
                        Got a resume?
                          Bertier
                          handy one !
                          • O Offline
                            openhatch
                            This just saved me a lot of trouble. πŸ˜„ Thanks!
