    Scaled array
    33 Posts 7 Posters 55.3k Views 7 Watching
      Maybe this πŸ˜„
      But in fact all gives cool results just try different little variations
      Palm's pull up is given by negative value πŸ˜‰
      Here with these regulates (click image)
      • utilerU Offline
        utiler
        Damn!
        I hate it when i feel amateurish... 😳
        Thanks Pilou, I think I am on the right track now. I will post some updates later.
        Thank you kindly for your persistence.
        Just Curious...
        • utilerU Offline
          utiler
          Ok, I have loaded the new 2.1 version...
          Did a little axis directions text [see attached.] It eems that the X axis directions are back to front. I would have thought that the postive directions would have been forward and the negative direction would be backwards....
          Also, rotations around the Z axis are anti-clockwise. I thought it makes sense to have postive rotations clockwise and negative rotations anticlockwise.... [see also attached]
          TIG, is there any reason for this?
          Eitherway, I think i have it worked out. πŸ‘
          Just Curious...
          • H Offline
            hsjzyangbin
            HI,TIG,i wish the picture just like show
              You need to experiment with the 'Growth Point' origin in different places ? πŸ˜•
                hm... I wonder if there is a copy+rotate plugin out here already...
                  @tig said:
                  My Grow.rb already does this - there is an example of how to make a helical staircase in its thread...
                  I'm not finding it easy to find it - is it this? http://forums.sketchucation.com/viewtopic.php?f=180&t=20195&p=168380&hilit=+grow#p168380
                  It'd be best if it was in a thread by itself and not buried inside another thread.
                    My Grow.rb already does this - there is an example of how to make a helical staircase in its threads...
                      @tig said:
                      Perhaps we could start a new thread to resurrect it - next week ?
                      That would be good.
                      Didier and Fredo had/has some old versions laying around as well. I noticed the last week several users seemed to have been downloading them instead of the new versions - despite noticed about newer versions. So I wanted to do a sweep of the plugin section and remove old versions and lock old obsolete threads. With the permission of the authors - in case they deliberately left them out there for legacy reasons.
                        Grow.rb is a pretty old thing - probably predates the Forum !
                        It's available from Didier's Depot and if you search by author [TIG] and 'Grow' there are several threads about it where I uploaded a version for convenience, there are also examples in some threads...
                        • H Offline
                          hsjzyangbin
                          Yes,I can do it with 'clf_component_stringer.rb'just like picture
                          • H Offline
                            hsjzyangbin
                            Hi,TIG,I wish Chris 'Component Stringer'and yous "GROW.RB" combine together
                              Seems only Grow is necessary! πŸ˜‰
                              Just make in 2 parts!
                              Select the previous group "growed" and grow again πŸ˜‰
                              Not a big deal πŸ˜„
                              • 2 / 2
