    [Request] Macro Push/Pull Library
    3 Posts 3 Posters 822 Views 3 Watching
    • K
      Khai
      got a rough idea for what could be a very useful ruby.
      basically a ruby that can string together a series of push/pull values into 1 operation which the user can setup before hand.
      an example: use the Ruby to create a boiler rivet. then you could click a face on another model and run the ruby - it then creates the rivet on that face.
      the library part would be saved values you can then take from project to project...
      • plot-parisP
        plot-paris
        I don't quite get, what you mean. although it sounds quite interesting. could you create a mock up image for further explanation? that would be marvellous
        • jim smithJ
          jim smith
          Khai at least for your example, it seems to me that creating a component and making copies or arrays where ever needed would be less memory use/poly creation and maybe quicker.
          "Out of clutter find simplicity,
          from discord find harmony,
          In the middle of difficulty lies opportunity"
          Albert Einstein
