    Let's have a Hardware speed test for SU
    132 Posts 72 Posters 88.7k Views 72 Watching
    • arail1A Offline
      arail1
      Gaieus -
      Those are impressive numbers. Could you tell us which CPU you have?
      • arail1A Offline
        arail1
        I'm curious about this -
        My (rather underpowered) computer -
        AMD Athlon 64x2 Dual Core 5000 2.6 GHz
        NIVIDIA GeForce 6150SE nForce 430
        1GB PC2-5300
        2GB DDR2 PC2-8500
        32 bit Vista Home
        My results -
        No textures or shadows:
        72 frames in 7.228 seconds
        Average frame = 0.100 seconds
        10.00 frames/second
        With textures (1 wood texture on the whole group):
        72 frames in 30.46 seconds
        Average frame = 0.423 seconds
        2.4 frames/second
        With shadows on:
        72 frames in 34.9 seconds
        Average frame = 0.485 seconds
        2.1 frames/second
        I'm going to upgrade the video card on this computer in a couple of weeks. I'm limited in my options because it's a HP Slimline so I can only use a low profile card. But no matter what it is, the memory available for the GPU will be increased. If I understand the situation correctly (which is doubtful) I should see better scores on the texture and shadow tests because it's the GPU that's handling texture and shading, right?
        I invite anyone who is actually knowledgeable about such matters to correct me if I've totally misunderstood this issue.
          @arail1 said:
          Gaieus -
          Here is a screenshot of the processor(s) and the video card. Since the test above, I found that SU performed glitchy with certain models and updated my video driver (but haven't made another test yet).
            Very interesting test. πŸ€“
            Without shadows
            With shadows
              Where does this Test.time_display command come from? Some undocumented debug feature?
                From a quick glance at the results - it looks like shadows are averaging to be 5 times slower than without.
                  Without shadows
                  (CPU OC to 3.2GHZ)
                  With Shadows
                    DIEGO-RODRIGUEZ
                    Windows XP sp3
                    Pentium D965 3.4ghz
                    3.00gb RAM ddr2 400mhz
                    Without shadows
                    http://img19.imageshack.us/img19/6665/testzzc.jpg
                      Still the same machine as here but with SU 7.1 now:
                      • 3.0 GHz Dual core CPU
                      • nVidia 9600 (1Gb) GPU
                      • 4Gb RAM
                      • Windows XP SP3 (32 bit)
                        To me, the improvement in speed (with this test model) is very stunning:
                      Shadows off
                      Shadows on
                      Interesting that no matter how many times I tried, the performance was better with shadows on. πŸ˜•
                      (Of course while making the test with shadows on now, SU temporarily turns them off for increasing orbiting and such but still...)
                        blajnov
                        I had such result, without shadows and with shadows...
                        • W Offline
                          Wacov
                          @wacov said:
                          Using a Q6600 at 2.4GhZ, 4GB DDR2 RAM, and a GTX 295:
                          Now, on SU7.1, using the same setup (At a higher resolution):
                          That's a massive difference!
                          The message? Get 7.1. NOW.
                          • bazB Offline
                            baz
                            [/quote]
                            The message? Get 7.1. NOW.[/quote]
                            I got the message, wow!
                            Baz
                            shad off V7.0
                            shad off, V7.1
                            • G Offline
                              glenn
                              Interesting test results:
                              XP sp3, duo 2.8, 4gb ram, 8500gt 512mb
                              Ran it with SU7.1, then saved it as SU6 and ran it with v6.4
                              Glenn
                              • G Offline
                                glenn
                                hmmmm...I can't upload multiple images?
                                ok, got it, sorry.
                                • brodieB Offline
                                  brodie
                                  I got 21.1 fps with shadows off.
                                  Computer specs are in my signature below
                                  -Brodie
                                    Glenn,
                                    Now that's some impressive speed increase (of course, there areno textures in the model and such but still)
                                    Brodie;
                                    OK-ok... there are your computer specs but we don't know (just suspect maybe) what SU version you have!
                                    • jeff hammondJ Offline
                                      jeff hammond
                                      i didn't run this pre su7.1 but i'm willing to assume a huge difference since upgrading...
                                      with an older quad mac..
                                      with shadow ON:
                                      shadows OFF:
                                      dotdotdot
                                      • W Offline
                                        Wacov
                                        Does SU run better on Macs? Or is it your RAM? Because... 150 fps... ? Wow...
                                        • U Offline
                                          Ultimatez 32
                                          Here's something odd.....I tried the test on 2 models, one the test model and the other one my roller coaster model. Here's the result.....quite suprising:
                                          coaster model
                                          test model
                                          The picture below shows my computer stats...... πŸ˜•
                                          It's a laptop by the way
                                          Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
                                            How about the video card and OpenGL hardware support ("acceleration" in Preferences > OpenGL)?
                                            • 6
                                            • 7
                                            • 3 / 7
