    Let's have a Hardware speed test for SU
    132 Posts 72 Posters 98.9k Views 72 Watching
    • Rich O BrienR Online
      Here's my result on an old laptop that's slowly dying 😒
      Dell Latitude D400
      Intel Pentium M 1700Mhz
      1GB RAM
      Intel 82855 GME Graphics Controller
      Without Shadows
      With Shadows
        Ouch. 😞
          Here's the result on my Desktop
          Dell Dimension 9150
          Intel Pentium D 3.40Ghz
          2GB RAM
          Nvidia GeForce 7900GS
          Without Shadows
          With Shadows
          Bit of an improvement over my Laptop but not as impressive as Gaeius' new machine 😳
          Have fun with it
            Now consider that it's new, the Windows registry is hardly messed up (which is unusual on MY machines πŸ˜„ )and not too many programs are installed yet. I will remember this thread in a couple of months and revisit to see if there's a considerable slowdown.
            • arail1A Offline
              arail1
              Gaieus -
              Those are impressive numbers. Could you tell us which CPU you have?
              • arail1A Offline
                arail1
                I'm curious about this -
                My (rather underpowered) computer -
                AMD Athlon 64x2 Dual Core 5000 2.6 GHz
                NIVIDIA GeForce 6150SE nForce 430
                1GB PC2-5300
                2GB DDR2 PC2-8500
                32 bit Vista Home
                My results -
                No textures or shadows:
                72 frames in 7.228 seconds
                Average frame = 0.100 seconds
                10.00 frames/second
                With textures (1 wood texture on the whole group):
                72 frames in 30.46 seconds
                Average frame = 0.423 seconds
                2.4 frames/second
                With shadows on:
                72 frames in 34.9 seconds
                Average frame = 0.485 seconds
                2.1 frames/second
                I'm going to upgrade the video card on this computer in a couple of weeks. I'm limited in my options because it's a HP Slimline so I can only use a low profile card. But no matter what it is, the memory available for the GPU will be increased. If I understand the situation correctly (which is doubtful) I should see better scores on the texture and shadow tests because it's the GPU that's handling texture and shading, right?
                I invite anyone who is actually knowledgeable about such matters to correct me if I've totally misunderstood this issue.
                  @arail1 said:
                  Gaieus -
                  Here is a screenshot of the processor(s) and the video card. Since the test above, I found that SU performed glitchy with certain models and updated my video driver (but haven't made another test yet).
                    Very interesting test. πŸ€“
                    Without shadows
                    With shadows
                      Where does this Test.time_display command come from? Some undocumented debug feature?
                        From a quick glance at the results - it looks like shadows are averaging to be 5 times slower than without.
                          Without shadows
                          (CPU OC to 3.2GHZ)
                          With Shadows
                            DIEGO-RODRIGUEZ
                            Windows XP sp3
                            Pentium D965 3.4ghz
                            3.00gb RAM ddr2 400mhz
                            Without shadows
                            http://img19.imageshack.us/img19/6665/testzzc.jpg
                              Still the same machine as here but with SU 7.1 now:
                              • 3.0 GHz Dual core CPU
                              • nVidia 9600 (1Gb) GPU
                              • 4Gb RAM
                              • Windows XP SP3 (32 bit)
                                To me, the improvement in speed (with this test model) is very stunning:
                              Shadows off
                              Shadows on
                              Interesting that no matter how many times I tried, the performance was better with shadows on. πŸ˜•
                              (Of course while making the test with shadows on now, SU temporarily turns them off for increasing orbiting and such but still...)
                                blajnov
                                I had such result, without shadows and with shadows...
                                • W Offline
                                  Wacov
                                  @wacov said:
                                  Using a Q6600 at 2.4GhZ, 4GB DDR2 RAM, and a GTX 295:
                                  Now, on SU7.1, using the same setup (At a higher resolution):
                                  That's a massive difference!
                                  The message? Get 7.1. NOW.
                                  • bazB Offline
                                    baz
                                    [/quote]
                                    The message? Get 7.1. NOW.[/quote]
                                    I got the message, wow!
                                    Baz
                                    shad off V7.0
                                    shad off, V7.1
                                      glenn
                                      Interesting test results:
                                      XP sp3, duo 2.8, 4gb ram, 8500gt 512mb
                                      Ran it with SU7.1, then saved it as SU6 and ran it with v6.4
                                      Glenn
                                        glenn
                                        hmmmm...I can't upload multiple images?
                                        ok, got it, sorry.
                                        • brodieB Offline
                                          brodie
                                          I got 21.1 fps with shadows off.
                                          Computer specs are in my signature below
                                          -Brodie
                                            Glenn,
                                            Now that's some impressive speed increase (of course, there areno textures in the model and such but still)
                                            Brodie;
                                            OK-ok... there are your computer specs but we don't know (just suspect maybe) what SU version you have!
                                            • 3 / 7
