    Let's have a Hardware speed test for SU
    132 Posts 72 Posters 98.9k Views 72 Watching
      diana
      Sony Vaio VGNFS660W laptop, which I've had for almost four years.
      Intel® Pentium® M Processor 740 (1.73GHz1 , 2MB L2 Cache)
      1GB PC-2700 333MHz DDR (512MB x 2)
      NVIDIA® GeForce™ Go 6200 with TurboCache™ supporting
      128MB (NVIDIA® TurboCache™ technology combines the size and
      bandwidth of video memory and dynamically available
      WinXP Home SP2
      VAIO laptop results
      • W Offline
        Wacov
        Using a Q6600 at 2.4GhZ, 4GB DDR2 RAM, and a GTX 295:
        I reckon I'm let down by my CPU clock. I get 2.5 FPS with shadows... and up to 15 FPS by making my SU window insanely small ^_^
          New machine:
          • 3.0 GHz Dual core CPU
          • nVidia 9600 (1Gb) GPU
          • 4Gb RAM
          • Windows XP SP3 (32 bit)
          This seems to be pretty fast with NO SHADOWS
          With SHADOWS ON, it's considerably slower.
          Did I tell you that I like this new computer? 😄
          And even my girlfriend likes it as it has a nice box/house, too (with a 22" Samsung monitor) 😉
            chango70
            @escapeartist said:
            It's way back at post #8 on page 1, but here ya go:
            E8400 Core Duo
            EVGA 9800GTX+ x 2 in SLi
            4 GB OCZ RAM
            EVGA 780i FTW
            WinXP SP3
            Nothing overclocked.
            Hmmm. I didn't realise SU can take advantage of SLi setup. I read that it doesn't even scale linearly in most games. Apparently it does scale with SU. Otherwise GTX 280 from Solo's setup would have achieved higher score.
            • Rich O BrienR Online
              Here's my result on an old laptop that's slowly dying 😢
              Dell Latitude D400
              Intel Pentium M 1700Mhz
              1GB RAM
              Intel 82855 GME Graphics Controller
              Without Shadows
              With Shadows
                Ouch. 😞
                  Here's the result on my Desktop
                  Dell Dimension 9150
                  Intel Pentium D 3.40Ghz
                  2GB RAM
                  Nvidia GeForce 7900GS
                  Without Shadows
                  With Shadows
                  Bit of an improvement over my Laptop but not as impressive as Gaeius' new machine 😳
                  Have fun with it
                    Now consider that it's new, the Windows registry is hardly messed up (which is unusual on MY machines 😄 )and not too many programs are installed yet. I will remember this thread in a couple of months and revisit to see if there's a considerable slowdown.
                    • arail1A Offline
                      arail1
                      Gaieus -
                      Those are impressive numbers. Could you tell us which CPU you have?
                      • arail1A Offline
                        arail1
                        I'm curious about this -
                        My (rather underpowered) computer -
                        AMD Athlon 64x2 Dual Core 5000 2.6 GHz
                        NIVIDIA GeForce 6150SE nForce 430
                        1GB PC2-5300
                        2GB DDR2 PC2-8500
                        32 bit Vista Home
                        My results -
                        No textures or shadows:
                        72 frames in 7.228 seconds
                        Average frame = 0.100 seconds
                        10.00 frames/second
                        With textures (1 wood texture on the whole group):
                        72 frames in 30.46 seconds
                        Average frame = 0.423 seconds
                        2.4 frames/second
                        With shadows on:
                        72 frames in 34.9 seconds
                        Average frame = 0.485 seconds
                        2.1 frames/second
                        I'm going to upgrade the video card on this computer in a couple of weeks. I'm limited in my options because it's a HP Slimline so I can only use a low profile card. But no matter what it is, the memory available for the GPU will be increased. If I understand the situation correctly (which is doubtful) I should see better scores on the texture and shadow tests because it's the GPU that's handling texture and shading, right?
                        I invite anyone who is actually knowledgeable about such matters to correct me if I've totally misunderstood this issue.
                          @arail1 said:
                          Gaieus -
                          Here is a screenshot of the processor(s) and the video card. Since the test above, I found that SU performed glitchy with certain models and updated my video driver (but haven't made another test yet).
                            Very interesting test. 🤓
                            Without shadows
                            With shadows
                              Where does this Test.time_display command come from? Some undocumented debug feature?
                                From a quick glance at the results - it looks like shadows are averaging to be 5 times slower than without.
                                  Without shadows
                                  (CPU OC to 3.2GHZ)
                                  With Shadows
                                    DIEGO-RODRIGUEZ
                                    Windows XP sp3
                                    Pentium D965 3.4ghz
                                    3.00gb RAM ddr2 400mhz
                                    Without shadows
                                    http://img19.imageshack.us/img19/6665/testzzc.jpg
                                      Still the same machine as here but with SU 7.1 now:
                                      • 4Gb RAM
                                        To me, the improvement in speed (with this test model) is very stunning:
                                      Shadows off
                                      Shadows on
                                      Interesting that no matter how many times I tried, the performance was better with shadows on. 😕
                                      (Of course while making the test with shadows on now, SU temporarily turns them off for increasing orbiting and such but still...)
                                        blajnov
                                        I had such result, without shadows and with shadows...
                                        • W Offline
                                          Wacov
                                          Now, on SU7.1, using the same setup (At a higher resolution):
                                          That's a massive difference!
                                          The message? Get 7.1. NOW.
                                          • bazB Offline
                                            baz
                                            [/quote]
                                            The message? Get 7.1. NOW.[/quote]
                                            I got the message, wow!
                                            Baz
                                            shad off V7.0
                                            shad off, V7.1
                                            • 3 / 7
