SketchUP 7 - Vista 64 bit problem
Hello everybody,
I have recently installed SketchUP 7 on my laptop which came with Vista 64 bit pre-installed. Yesterday I had problem with a particular file (which is 31 MB size). I get the message "File open failed". This same file opens perfectly on SketchUP 6 installed on this same machine. I even un-installed SU7 and re-installed it. Still the same problem persists. I am unable to post the file because of it's big size. But since it is opening in SU6, the problem is not with the file. Can somebody throw any light on this? (By the way, this laptop has a GeForce Go 7400 card, 3 Gig RAM. Also this file opens well in my desktop which has XP).
Thanks in advance
With best regards
PRSS -
If your feeling keen you could upload the file to megaupload: http://www.megaupload.com/
Not really sure what might be causing the file to not open in SU7 though, most peculiar.
Try re-saving to another file from SU6? Or copy model to a new model?
Thank you Remus and Thomthom, I copied the model and pasted it in another new file in SU6. But this has not solved the problem. This is happening only with this particular file. Anyway, I shall manage with SU6 for this file.
Because of my slow internet connection I am unable to upload the file.
With best regards
PRSS
Register LoginAdvertisement
