    Odd results from Soap Skin Bubble
    19 Posts 6 Posters 1.6k Views 6 Watching
    • ToboboT Offline
      Tobobo
      Hi Everybody
      I've been getting odd spikes when I use SSB (image below). The near line is one entity and the far one is broken but same results.
      Any ideas?
      Toby
      Philippians 4:13
        Post an example of your skp object!
          remus
          What sort of scale are you working on? Ive known SSB to do weird things at small scales...
          • ToboboT Offline
            Tobobo
            I'm drawing in mm but the units are in m
            I'll post the model tomorrow when I get back to work
            I'm using it to model a seat
            till tomorrow........
            EDIT: here is the file
            Seat Test.skp
            Toby
            Philippians 4:13
            • K Offline
              kwistenbiebel
              I would like to try SSB to mimic the issue.....but it has expired again... Extremely annoying 😡
                @Kwist
                Load the new Beta! Expire the 10 October 2009 😉
                • K Offline
                  kwistenbiebel
                  Thanks frenchy...I will have to do that. (I vote for lifting the time constraint though)
                  • mitcorbM Offline
                    mitcorb
                    I got the same thing. Spikes along the edges of a model. To fix, I just moved vertices to the proxy outline. Of course, the oddity shouldn't happen at all, but may be something in the newest version. Oct. 10, 2009.
                    mitcorb
                    edited, wrong addressee.
                    • ToboboT Offline
                      Tobobo
                      I have been correcting it myself but I can't get the smoothness that matches the rest of the skin
                      Toby
                      Philippians 4:13
                        How can we can help if we have not file 😒
                          You mean this file? http://forums.sketchucation.com/viewtopic.php?f=180&t=20062#p166861 😉
                            Ahhhhhhhh yes this one 😄
                            But seems more useful if it's the file before the soap! 😉
                            • ToboboT Offline
                              Tobobo
                              I've scaled the model up to mm and it seems to be ok, maybe i was working too small
                              Toby
                              Philippians 4:13
                              • mitcorbM Offline
                                mitcorb
                                to approximate the smoothness, draw a segment across the depression, use move tool with alt key to position the vertex visually on the added segment.
                                hope this helps
                                • ToboboT Offline
                                  Tobobo
                                  Thanks I'll try that.
                                  It doesn't happen so much working in mm as it did working in m but it still happens. Odd?
                                  Toby
                                  Philippians 4:13
                                    Can you post the model before Soaping?
                                    • ToboboT Offline
                                      Tobobo
                                      Sorry for the delay been really stacked at work
                                      Before SSB.skp
                                      Toby
                                      Philippians 4:13
                                        I have not your artifacts because I have taken less subdivisions like you 😉
                                        The only problem is that you must make all the volume in a one big soap surface else you can't have continuity! Or make no pressure!
                                        SSB.zip
                                        • ToboboT Offline
                                          Tobobo
                                          Thank you Pilou.
                                          It is a complex shape and to get the curves and presures you need to divide it up. maybe I should invest in Sub/smooth.
                                          Toby
                                          Philippians 4:13
