    Odd results from Soap Skin Bubble
    19 Posts 6 Posters 2.0k Views 6 Watching
    • ToboboT
      Tobobo
      I'm drawing in mm but the units are in m
      I'll post the model tomorrow when I get back to work
      I'm using it to model a seat
      till tomorrow........
      EDIT: here is the file
      Seat Test.skp
      Toby
      Philippians 4:13
      • K
        kwistenbiebel
        I would like to try SSB to mimic the issue.....but it has expired again... Extremely annoying 😡
          @Kwist
          Load the new Beta! Expire the 10 October 2009 😉
          • K
            kwistenbiebel
            Thanks frenchy...I will have to do that. (I vote for lifting the time constraint though)
            • mitcorbM
              mitcorb
              I got the same thing. Spikes along the edges of a model. To fix, I just moved vertices to the proxy outline. Of course, the oddity shouldn't happen at all, but may be something in the newest version. Oct. 10, 2009.
              mitcorb
              edited, wrong addressee.
              • ToboboT
                Tobobo
                I have been correcting it myself but I can't get the smoothness that matches the rest of the skin
                Toby
                Philippians 4:13
                  How can we can help if we have not file 😒
                    You mean this file? http://forums.sketchucation.com/viewtopic.php?f=180&t=20062#p166861 😉
                      Ahhhhhhhh yes this one 😄
                      But seems more useful if it's the file before the soap! 😉
                      • ToboboT
                        Tobobo
                        I've scaled the model up to mm and it seems to be ok, maybe i was working too small
                        Toby
                        Philippians 4:13
                        • mitcorbM
                          mitcorb
                          to approximate the smoothness, draw a segment across the depression, use move tool with alt key to position the vertex visually on the added segment.
                          hope this helps
                          • ToboboT
                            Tobobo
                            Thanks I'll try that.
                            It doesn't happen so much working in mm as it did working in m but it still happens. Odd?
                            Toby
                            Philippians 4:13
                              Can you post the model before Soaping?
                              • ToboboT
                                Tobobo
                                Sorry for the delay been really stacked at work
                                Before SSB.skp
                                Toby
                                Philippians 4:13
                                  I have not your artifacts because I have taken less subdivisions like you 😉
                                  The only problem is that you must make all the volume in a one big soap surface else you can't have continuity! Or make no pressure!
                                  SSB.zip
                                  • ToboboT
                                    Tobobo
                                    Thank you Pilou.
                                    It is a complex shape and to get the curves and presures you need to divide it up. maybe I should invest in Sub/smooth.
                                    Toby
                                    Philippians 4:13
