    Odd results from Soap Skin Bubble
    19 Posts 6 Posters 2.0k Views 6 Watching
    • ToboboT
      Tobobo
      I have been correcting it myself but I can't get the smoothness that matches the rest of the skin
      Toby
      Philippians 4:13
        How can we can help if we have not file πŸ˜’
          You mean this file? http://forums.sketchucation.com/viewtopic.php?f=180&t=20062#p166861 πŸ˜‰
            Ahhhhhhhh yes this one πŸ˜„
            But seems more useful if it's the file before the soap! πŸ˜‰
            • ToboboT
              Tobobo
              I've scaled the model up to mm and it seems to be ok, maybe i was working too small
              Toby
              Philippians 4:13
              • mitcorbM
                mitcorb
                to approximate the smoothness, draw a segment across the depression, use move tool with alt key to position the vertex visually on the added segment.
                hope this helps
                • ToboboT
                  Tobobo
                  Thanks I'll try that.
                  It doesn't happen so much working in mm as it did working in m but it still happens. Odd?
                  Toby
                  Philippians 4:13
                    Can you post the model before Soaping?
                    • ToboboT
                      Tobobo
                      Sorry for the delay been really stacked at work
                      Before SSB.skp
                      Toby
                      Philippians 4:13
                        I have not your artifacts because I have taken less subdivisions like you πŸ˜‰
                        The only problem is that you must make all the volume in a one big soap surface else you can't have continuity! Or make no pressure!
                        SSB.zip
                        • ToboboT
                          Tobobo
                          Thank you Pilou.
                          It is a complex shape and to get the curves and presures you need to divide it up. maybe I should invest in Sub/smooth.
                          Toby
                          Philippians 4:13
