    Odd results from Soap Skin Bubble
    19 Posts 6 Posters 1.1k Views 6 Watching
      @Kwist
      Load the new Beta! Expire the 10 October 2009 😉
        kwistenbiebel
        Thanks frenchy...I will have to do that. (I vote for lifting the time constraint though)
        • mitcorbM Offline
          mitcorb
          I got the same thing. Spikes along the edges of a model. To fix, I just moved vertices to the proxy outline. Of course, the oddity shouldn't happen at all, but may be something in the newest version. Oct. 10, 2009.
          mitcorb
          edited, wrong addressee.
          • ToboboT Offline
            Tobobo
            I have been correcting it myself but I can't get the smoothness that matches the rest of the skin
            Toby
            Philippians 4:13
              How can we can help if we have not file 😒
                You mean this file? http://forums.sketchucation.com/viewtopic.php?f=180&t=20062#p166861 😉
                  Ahhhhhhhh yes this one 😄
                  But seems more useful if it's the file before the soap! 😉
                  • ToboboT Offline
                    Tobobo
                    I've scaled the model up to mm and it seems to be ok, maybe i was working too small
                    Toby
                    Philippians 4:13
                    • mitcorbM Offline
                      mitcorb
                      to approximate the smoothness, draw a segment across the depression, use move tool with alt key to position the vertex visually on the added segment.
                      hope this helps
                      • ToboboT Offline
                        Tobobo
                        Thanks I'll try that.
                        It doesn't happen so much working in mm as it did working in m but it still happens. Odd?
                        Toby
                        Philippians 4:13
                          Can you post the model before Soaping?
                          • ToboboT Offline
                            Tobobo
                            Sorry for the delay been really stacked at work
                            Before SSB.skp
                            Toby
                            Philippians 4:13
                              I have not your artifacts because I have taken less subdivisions like you 😉
                              The only problem is that you must make all the volume in a one big soap surface else you can't have continuity! Or make no pressure!
                              SSB.zip
                              • ToboboT Offline
                                Tobobo
                                Thank you Pilou.
                                It is a complex shape and to get the curves and presures you need to divide it up. maybe I should invest in Sub/smooth.
                                Toby
                                Philippians 4:13
