    Help: Resize Multiple Circles
    15 Posts 6 Posters 3.9k Views 6 Watching
    • F Offline
      freddig
      Hi All,
      I use Sketchup to design electrical panels. Along each outer edge of a panel I will have a series of drilled holes. Sometimes I need to change the size of these holes, but Sketchup will only let me change the radius of one circle at a time; I can't select and resize multiple circles (even if they are all the same size). I've tried the scale tool but it does weird things. I'm I missing something or is there a plugin that might do the job?
      Many thanks
      Can Resize One Circle
      Can't Resize Multiple Circle
      • ely862meE Offline
        ely862me
        if u make one hole a component and then multiply it when u want to change one hole will change all of them
        Elisei (sketchupper)
        Come and See EliseiDesign
          Yes, what Ely says. Components have the advantage (beside others) that f you edit one instance in a model, all the other instances (copies) update instantly. Read more about components here.
          Note however that though components can even cut a hole on a surface automatically, they can only do this on ONE surface so you may not be able to use them in your particular model above as you'd wish (although there are "workarounds").
          • F Offline
            freddig
            I had tried using a component but as you've said it only cut the hole in one surface. If I created a component from the two circles and joining faces, no hole was cut. I was sort of hoping that there would be a way to change the radius entity property for a multi-selection as you can do for layers. I looked at looks of plugins but nothing suitable.
            Regards
              I said "there are workarounds" - it's just a matter of consideration whether it's worth investing time into using them or not. In the attached file, there are four instances of the same component (with two, further components nested in each) are placed. As you can see, the bottom faceof the panel (?) is not cut through, just as you also know.
              You can however manipulate the "hole" components without any problem; scale them (only along their red/green axes so that the "thickness" won't change) and at the end, if you select all > Right click > Explode, the nested components "regain" their own cutting behaviour and each cuts through a face.
              Of course, this should only be done when you are ready with positioning, scaling, texturing - everything that makes the use of a component with multiple instances being edited at the same time "handy".
              Hole.skp
              • Jean LemireJ Offline
                Jean Lemire
                Hi Freddig, hi folks.
                See attached SU file for ideas.
                Changing multiple holes.skp
                • F Offline
                  freddig
                  Hi Gaieus and Jean,
                  Brillant, now I have two solutions. Some great lateral thinking.
                  Many thanks for your help guys ๐Ÿ‘
                    That's because we went to the same bar together the first night when visiting Googleplex in Mountain View last year.
                    ๐Ÿคฃ
                      How will this resize/update several holes at once, Pilou?
                        Seems there is very more easy ๐Ÿ’š
                        I must think of that ๐Ÿ’š
                          You are more speedy that me ๐Ÿ˜„
                          I had writing before to try ๐Ÿ˜†
                            He... and you also edited your previous post
                            ๐Ÿ˜‰
                              mac1
                              @freddig said:
                              Hi All,
                              Many thanks
                              As always there are many ways of doing things in SU. Here is another idea:
                              1. Establish center point ( guide point) of each existing hole , then delete hole;
                              2. Select the center point(s) and make a them component;
                              3. Draw the circle(s) you want to use as replacements and make components;
                              4. Select the old center point where you want to change circle size;
                              5. Using the component browser, select the desired circle you want to use as replacment and then select replace selected
                              6. Explode the replacement circles and extrude thru your panel
                                Not :Make sure you have the insertion point correct else the replacements will not align with desired location
                                so must find a plug who convert a selection with some object in group or component
                                (must be existing)
                                Yes by Chris Fullmer again at Smustard Loos2groups Modify here
                                But some work around must be made for my work with the case of the posts above!
                                Stay connected ๐Ÿ˜„
                                  Yep ๐Ÿ˜ณ
                                  Not find yet something tricky except the plug of Chris Fullmer ๐Ÿ’š
                                  Scale and rotate Multiple ๐Ÿ˜‰
                                  Works fine with different objects in the same times!
                                  Each "hole circle" must be a group or a "components"
                                  The good parameter is Scale about "Center" for the Chris Fullmer plug
                                  if not group or cmponent must find a plug who convert a selection with some object in group or component
                                  (must be existing)yes see 2 posts following
                                  Alas the problem are the "black empty white holes" ๐Ÿ˜ฎ
                                  So work on a "plan" then push pull it at the end ๐Ÿ˜‰
                                  Workflow can be
                                  Explode all
                                  Select the the up face plane with the holes
                                  Kill inverse selection
                                  Group each Holes (this now is made by hand but maybe will automatic in few time*****) (see 2 post following)
                                  Apply Scale and rotate multiple By Chris Fullmer (center)
                                  Explode all
                                  Push pull
                                  ***** Now you can yet make this
                                  Select "holes"
                                  move it in the empty space
                                  Apply the plug (Loos2groups) = each holes becomes a "group"
                                  Move it at old place
