    Render challenge - water caustics
    35 Posts 19 Posters 16.2k Views 19 Watching
    • RichardR Offline
      Richard
      Hey those modo images are amazing!
      Maxwell - faked!
      http://img23.imageshack.us/img23/8108/typicalunitsdraftimage7.jpg
      http://img177.imageshack.us/img177/3204/70225399bt6.jpg
      Maxwell night - faked! 5 min test render! Needed longer!
      http://img185.imageshack.us/img185/485/pooltq6.jpg
      BUILTBRAND.COM.AU
      • majidM Offline
        majid
        here are other renderes from differenr scene.. it seems that KT has good caustics handling , but the water material , doesn't let that the caustics be seen from top view ...
        from below water view
        • F Offline
          Fred
          I tried something to.
          http://img3.imageshack.us/img3/4258/waterf.png
          • daleD Offline
            dale
            @majid said:
            if you are going to have a better result , maybe give a try over dielectric glass shader ... or maybe download waterpack I've prepared some while ago :
            http://www.kerkythea.net/joomla/index.php?option=com_remository&Itemid=42&func=fileinfo&id=86
            also less bump over Z direction is needed...and the best result for true caustics would be reached , using preset no 20...
            also u may have your camera , just below water surface πŸ˜‰ ( give it a try πŸ‘ )
            Thanks majid
            I hope to get time to try this. I do have, and use your waterpack quite often, (thanks for that), but when I try these challenges I like to try to do them from scratch to try and understand some of the principles, and controls and their variables. It also makes me go through some of the tips, tricks, and tutorials on the Kerkythea forum site, from which I always learn.
            Thanks for the help.
            • olisheaO Offline
              olishea
              solo....how did u fake the podium caustics?
              oli
              • soloS Offline
                solo
                Oliver, it's done with a light and a caustic pattern overlaid onto a texture in PS, actually very simple. Now with blurred reflections and bump mapping it can be done even better.
                http://www.solos-art.com
                • olisheaO Offline
                  olishea
                  thanks for the reply pete
                  oli
                  • daleD Offline
                    dale
                    another attempt
                      sepo
                      Richard , that wood panel texture is great. Could you tell what it is? Arroway? Love that pool render. Nice, clean design.
                      • RichardR Offline
                        Richard
                        Thanks mate the design is one of my own! The texture for the timber panel? The one with the screws in I might have edited an arroway and rebuilt to rid the tiling, fix colour and bump, add screws etc. I get so anal the screws even have the head bumped and discoloration of the timber around the head along the grain and the decking a slight cupping in the bump!! My mother was german!
                        http://img193.imageshack.us/img193/5108/striptimberpanelling.jpg
                        BUILTBRAND.COM.AU
                          sepo
                          LOL...I am using one made from the photo taken from the project I designed (self referencing πŸ˜‰ )
                            dtrarch
                            Here is a KT photon mapped quick render
                            Lots of water features too.
                            dtr
                              jmmad
                              Hi, here is my try using v-ray with GI sun.
                              I followed this tutorial http://software.asgvis.com/index.php?option=com_docman&task=doc_details&gid=594&Itemid=439&uid=0
                              I used as primary engine Irradiance Map
                              And second engine deterministic Monte Carlo GI
                              Caustics On
                              Max Photons 100 Multiplier 300 search distance 5,0
                              Environment
                              GI: Sky, Sunlight,
                              Photon Emit Distance 100000
                              Caustic Subdivs 10000
                              Get Upa !
                              • G Offline
                                guagab
                                @21d said:
                                this is my try....it's a simple box, with a flat rect. geo.
                                sent to modo401....textured and rendered
                                hello can i know how you did the water. im an paris architects and realy i need for a project. tnk a lot
                                gabriele
                                  Brighter3D
                                  brighter3d PRO 2.0 (not yet available).
                                  Model from previous rendering competition (a bit cut).
                                  True caustics.
                                  Settings:
                                  Caustics:10
                                  Adjust lighting: caustics = 8.90, rest = 0.0
                                  Sun samples: 64
                                  Sky samples: 781
                                  HDR map only as a backround
                                  Overall time: 128 seconds
                                  • 2 / 2
