    Render challenge - water caustics
    35 Posts 19 Posters 16.4k Views 19 Watching
      remus
      Yeah, just a big volume:
      Made using jim's randomise TIN script followed by 2 SDSs.
        21D
        this is my try....it's a simple box, with a flat rect. geo.
        sent to modo401....textured and rendered
        Modo 401 handels CAUSTICS now
        screengrab for some SPECS
        "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
        Le Corbusier
        • soloS
          Excellent Modo 401 show piece, so how is the new Modo so far?
          Here is a faked caustic I did in December 2006, using Podium version 1.0.
          http://img224.imageshack.us/img224/286/2006121705520621m17sqo8.jpg
            sepo
            This brings some memories 😄
              21D
              Well haven't played to much with it, only been test running it.....the "fur" ellement is just amazing...i'll see if i can post a sample of it used to creat a grass field.
              as you could see the caustics also looks good, even though i have a dual core machine, it renders pretty fast (see the caustics render screengrab), i am now going to try out the blurry refractions...
              but all in all, amazing.
              it's a bit more aimed now for archvis with all the presets that can be used,
              i am definitly going to learn how to use it, so i can add it to my archvis workflow.
              Le Corbusier
              • majidM
                majid
                congrats Solo... it is an art work, out of podium!!! 👍
                • daleD
                  dale
                  Well not totally satisfied yet, but though I'd post the progression.
                  Kerkythea
                  Water Surface is thin glass, IOR 1.33, color changed to blueish, Perlin Noise Fresnel added
                  Rendered with Preset 09 Photon Caustics Medium
                  • majidM
                    majid
                    Kerkythea
                    if you are going to have a better result , maybe give a try over dielectric glass shader ... or maybe download waterpack I've prepared some while ago :
                    http://www.kerkythea.net/joomla/index.php?option=com_remository&Itemid=42&func=fileinfo&id=86
                    also less bump over Z direction is needed...and the best result for true caustics would be reached , using preset no 20...
                    also u may have your camera , just below water surface 😉 ( give it a try 👍 )
                    • RichardR
                      Richard
                      Hey those modo images are amazing!
                      Maxwell - faked!
                      http://img23.imageshack.us/img23/8108/typicalunitsdraftimage7.jpg
                      http://img177.imageshack.us/img177/3204/70225399bt6.jpg
                      Maxwell night - faked! 5 min test render! Needed longer!
                      http://img185.imageshack.us/img185/485/pooltq6.jpg
                      BUILTBRAND.COM.AU
                      • majidM
                        majid
                        here are other renderes from differenr scene.. it seems that KT has good caustics handling , but the water material , doesn't let that the caustics be seen from top view ...
                        from below water view
                        • F
                          Fred
                          I tried something to.
                          http://img3.imageshack.us/img3/4258/waterf.png
                          • daleD
                            dale
                            Thanks majid
                            I hope to get time to try this. I do have, and use your waterpack quite often, (thanks for that), but when I try these challenges I like to try to do them from scratch to try and understand some of the principles, and controls and their variables. It also makes me go through some of the tips, tricks, and tutorials on the Kerkythea forum site, from which I always learn.
                            Thanks for the help.
                            • olisheaO
                              olishea
                              solo....how did u fake the podium caustics?
                              oli
                              • soloS
                                Oliver, it's done with a light and a caustic pattern overlaid onto a texture in PS, actually very simple. Now with blurred reflections and bump mapping it can be done even better.
                                • olisheaO
                                  olishea
                                  thanks for the reply pete
                                  oli
                                  • daleD
                                    dale
                                    another attempt
                                      sepo
                                      Richard , that wood panel texture is great. Could you tell what it is? Arroway? Love that pool render. Nice, clean design.
                                      • RichardR
                                        Richard
                                        Thanks mate the design is one of my own! The texture for the timber panel? The one with the screws in I might have edited an arroway and rebuilt to rid the tiling, fix colour and bump, add screws etc. I get so anal the screws even have the head bumped and discoloration of the timber around the head along the grain and the decking a slight cupping in the bump!! My mother was german!
                                        http://img193.imageshack.us/img193/5108/striptimberpanelling.jpg
                                        BUILTBRAND.COM.AU
                                          sepo
                                          LOL...I am using one made from the photo taken from the project I designed (self referencing 😉 )
                                            dtrarch
                                            Here is a KT photon mapped quick render
                                            Lots of water features too.
                                            dtr
                                            • 2 / 2
