    Render challenge - water caustics
    35 Posts 19 Posters 15.5k Views 19 Watching
      sepo
      This brings some memories πŸ˜„
      • 2 Offline
        21D
        @solo said:
        Excellent Modo 401 show piece, so how is the new Modo so far?
        Well haven't played to much with it, only been test running it.....the "fur" ellement is just amazing...i'll see if i can post a sample of it used to creat a grass field.
        as you could see the caustics also looks good, even though i have a dual core machine, it renders pretty fast (see the caustics render screengrab), i am now going to try out the blurry refractions...
        but all in all, amazing.
        it's a bit more aimed now for archvis with all the presets that can be used,
        i am definitly going to learn how to use it, so i can add it to my archvis workflow.
        "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
        Le Corbusier
        • majidM Offline
          majid
          @solo said:
          Here is a faked caustic I did in December 2006, using Podium version 1.0.
          http://img224.imageshack.us/img224/286/2006121705520621m17sqo8.jpg
          congrats Solo... it is an art work, out of podium!!! πŸ‘
          • daleD Offline
            dale
            Well not totally satisfied yet, but though I'd post the progression.
            Kerkythea
            Water Surface is thin glass, IOR 1.33, color changed to blueish, Perlin Noise Fresnel added
            Rendered with Preset 09 Photon Caustics Medium
            • majidM Offline
              majid
              Kerkythea
              if you are going to have a better result , maybe give a try over dielectric glass shader ... or maybe download waterpack I've prepared some while ago :
              http://www.kerkythea.net/joomla/index.php?option=com_remository&Itemid=42&func=fileinfo&id=86
              also less bump over Z direction is needed...and the best result for true caustics would be reached , using preset no 20...
              also u may have your camera , just below water surface πŸ˜‰ ( give it a try πŸ‘ )
              • RichardR Offline
                Richard
                Hey those modo images are amazing!
                Maxwell - faked!
                http://img23.imageshack.us/img23/8108/typicalunitsdraftimage7.jpg
                http://img177.imageshack.us/img177/3204/70225399bt6.jpg
                Maxwell night - faked! 5 min test render! Needed longer!
                http://img185.imageshack.us/img185/485/pooltq6.jpg
                BUILTBRAND.COM.AU
                • majidM Offline
                  majid
                  here are other renderes from differenr scene.. it seems that KT has good caustics handling , but the water material , doesn't let that the caustics be seen from top view ...
                  from below water view
                  • F Offline
                    Fred
                    I tried something to.
                    http://img3.imageshack.us/img3/4258/waterf.png
                    • daleD Offline
                      dale
                      Thanks majid
                      I hope to get time to try this. I do have, and use your waterpack quite often, (thanks for that), but when I try these challenges I like to try to do them from scratch to try and understand some of the principles, and controls and their variables. It also makes me go through some of the tips, tricks, and tutorials on the Kerkythea forum site, from which I always learn.
                      Thanks for the help.
                      • olisheaO Offline
                        olishea
                        solo....how did u fake the podium caustics?
                        oli
                        • soloS Offline
                          Oliver, it's done with a light and a caustic pattern overlaid onto a texture in PS, actually very simple. Now with blurred reflections and bump mapping it can be done even better.
                          • olisheaO Offline
                            olishea
                            thanks for the reply pete
                            oli
                            • daleD Offline
                              dale
                              another attempt
                                sepo
                                Richard , that wood panel texture is great. Could you tell what it is? Arroway? Love that pool render. Nice, clean design.
                                • RichardR Offline
                                  Richard
                                  Thanks mate the design is one of my own! The texture for the timber panel? The one with the screws in I might have edited an arroway and rebuilt to rid the tiling, fix colour and bump, add screws etc. I get so anal the screws even have the head bumped and discoloration of the timber around the head along the grain and the decking a slight cupping in the bump!! My mother was german!
                                  http://img193.imageshack.us/img193/5108/striptimberpanelling.jpg
                                  BUILTBRAND.COM.AU
                                    sepo
                                    LOL...I am using one made from the photo taken from the project I designed (self referencing πŸ˜‰ )
                                      dtrarch
                                      Here is a KT photon mapped quick render
                                      Lots of water features too.
                                      dtr
                                        jmmad
                                        Hi, here is my try using v-ray with GI sun.
                                        I followed this tutorial http://software.asgvis.com/index.php?option=com_docman&task=doc_details&gid=594&Itemid=439&uid=0
                                        I used as primary engine Irradiance Map
                                        And second engine deterministic Monte Carlo GI
                                        Caustics On
                                        Max Photons 100 Multiplier 300 search distance 5,0
                                        Environment
                                        GI: Sky, Sunlight,
                                        Photon Emit Distance 100000
                                        Caustic Subdivs 10000
                                        Get Upa !
                                          guagab
                                          @21d said:
                                          this is my try....it's a simple box, with a flat rect. geo.
                                          sent to modo401....textured and rendered
                                          hello can i know how you did the water. im an paris architects and realy i need for a project. tnk a lot
                                          gabriele
                                            Brighter3D
                                            brighter3d PRO 2.0 (not yet available).
                                            Model from previous rendering competition (a bit cut).
                                            True caustics.
                                            Settings:
                                            Caustics:10
                                            Adjust lighting: caustics = 8.90, rest = 0.0
                                            Sun samples: 64
                                            Sky samples: 781
                                            HDR map only as a backround
                                            Overall time: 128 seconds
                                            • 2 / 2
