    Searching for better "Select" plugin
    4 Posts 3 Posters 367 Views 3 Watching
      junky
      To make walls from a dwg file, I have to draw lines/rectangles step by step,
      I saw somewhere on a tutorial video but could not find that video again. On that video, the person imports an AutoCAD dwg file, selects with that better select plugin all rooms walls than with Push/Pull tool he immadiatly makes walls.
      Can anyone help me to find that plugin?
        Hi Junky,
        There are a good deal of different "selection toys" (one in fact named like this) as available plugins. However what you describe seems not to be a selection problem but (automatically) creating faces. Could you somehow find and link that video here so we can have a clue which direction to point you?
          junky
          "automaticly creating faces" maybe is it that what I'm searching. I can't find that video again. When I import 2D dwg plan with stairs walls I want to draw walls on it. Now I have to draw the walls step by step line to line, which plugin can make "faces from the walls? then I need only to use push tool to create walls
          • massimoM Offline
            massimo Moderator
            Take a look at this.
            http://www.smustard.com/scripts/
            It's called "Make faces".
