    Models in realistic Terrains and creation of roads
    47 Posts 10 Posters 8.8k Views 10 Watching
    • M
      mirjman
      i have to agree that max seems to have the solution you are looking for, but you could probably do most of the up-front work shown in the video with follow me tool??
      • troyhomeT
        troyhome
        @charly2008 said:
        Hi Pete,
        i don't have a special projekt for creating a road. It is a general question for any triangulated terrain. For example the attached terrain.
        Karlheinz
        trippy terrain!
        IOviz.com
        SU Pro 2024 PC
        • charly2008C
          charly2008
          Hi Max,
          I do not claim your method to be wrong. But how would you use the method along the line in the valley in the attached skp so that it looks realistic?
          Karlheinz
          terrain from GE
          • soloS
            solo
            I did a very quick test using Vue to create a basic terrain, exported to SU, used Tools on the surface to draw a path, copied the path, welded it and used TIG's Extrude line, vector by 2 points ruby to create road, then used JPP to pull thickness. Exported the road to Vue and embedded into terrain, added texture a few tress and 2 cars.
            I could have taken more time and made road smoother and more curvy with more segmented arches.
            http://img40.imageshack.us/img40/3498/testterrain4road.jpg
            SU
            http://img43.imageshack.us/img43/7595/terrain4csu.jpg
            Quick Vue render
            http://www.solos-art.com
            • CadFatherC
              CadFather
              Charley, did you give it a try my way?
              @ Griffith.. Thanks
              • charly2008C
                charly2008
                Theoretical steps for a road in a sketchup terrain.
                Creation of a road course in 2D above the terrain
                Creation of the Height profil of the terrain along the road course
                projecting the terrain height profil to a to a vertical face
                On this projected flat Profile one could construct the height profile of the road.
                The height profile of the road then should be projected back on the 3D terrain height profil surface
                Then along this line the road cold be done by follow me and afterwards inserted into the terrain
                Please have a look at the attached skp. My description may not be clear.
                The Projections shown in this file are faked. I tried to make the projection with unfold.rb but it was not successfull.
                Karlheinz
                • GaieusG
                  You cannot use the "simple" follow me tool on that path because it bends in 3D and the road will twist. You can either use Follow me and keep or use Shape bender so that your road surface remains "flat" (This is why simply draping the road into the surface - like Pete's example above - will only work on more or less flat parts like along a valley line and such).
                  • soloS
                    solo
                    Firstly I'd subdivide the terrain more as the one in the above attachment is too jaggy and the resulting road path will have sharp turns and steep pointy hills.
                    Next, to achieve what you are looking for one will need a ruby that can perform the 'follow me' with the ruby 'perpendicular to face', Calling Mr. Fullmer for this one, as this will be the best solution IMO.
                    • charly2008C
                      charly2008
                      Hi Csaba,
                      you are right. I also meant the Follow me and keep plugin. What's about the whole Idea? The idea came to me when i had a look at some civil engineerung some CAD Brochures like this one attached.
                      Karlheinz
                      WhitePaperPowelTerrain.pdf
                      • GaieusG
                        There's some problem with the pdf document (it says there's some error in it and acrobat cannot display).
                        I've been playing around with an example model for a while and once I put something useful together, I can show.
                        Pete's right that more subdivision can enhance the connection between the road and terrain however. Sometimes you may feel that it's not what you want while you may be on the right track just need some more facets for a convincing solution.
                        • charly2008C
                          charly2008
                          Csaba,
                          here is the link to this PDF
                          http://www.powel.com/pictures/WhitePaperPowelTerrain.pdf
                          • charly2008C
                            charly2008
                            csaba,
                            please show your example model.
                            Karlheinz
                            • GaieusG
                              OK, this works.
                              Yes, I can see the problem (especially well demonstrated in these sections)
                              This is what the Stamp tool would be good for in SU once you finally have the road itself (even if "floating").
                              The only problem for me currently is that you cannot really lead a road in any of the directions so an additional tool which helps you define a "maximum steepness" of the centerline for instance would be helpful. It could "force" the centerline to meander like a snake path if the steepness of the hillside is bigger than what could be set.
                              Sorry, I tend to play around all the time with my examples but eventually never save anything unsuccessful. I could put together what I have figured out but it would probably disregard those "rules" mentioned above.
                              • charly2008C
                                charly2008
                                Hi Pete,
                                Your rendered image above is top class and consistently good.
                                I agree with you. but if i subdivide the terrain more, it slows down the speed of my PC respectively Sketchup speed very much. But your idea to create the road directly in the 3D space would may be the easiest way.
                                I will follow up also with the above posted idea. May be we have an civil engineer in the SCF with experience in CAD who can give us some input.
                                Karlheinz
                                • charly2008C
                                  charly2008
                                  Hi Csaba,
                                  i thought about the method to unroll the height profile. The method in german is called "Blechabwicklung" i didn't find the correct english expression. It could be done in this example manually but it would be a boring work and on a high detailed profil it would be impossible. If this method could be done automatically then we would come closer to the solution. I had a look at the projecting tools from Didier Bur but there is also no tool which fits. May be i will contact Didier Bur.
                                  Karlheinz
                                  • GaieusG
                                    If you thought of shape bender, the "unrolled" profile should be as long (only) as the winding profile's projection and only a straight piece as well. The ruby would take care of the rest.
                                    • charly2008C
                                      charly2008
                                      Hi Scaba,
                                      i didn't think about shape bender. But now i tried it. Im not shure if it is still working.
                                      Karlheinz
                                      • GaieusG
                                        What is not working?
                                        • charly2008C
                                          charly2008
                                          after about 10 minutes i saw in the taskbar three options, one of them i choosed (pressing Enter to finalize Bending). But there was no result.
                                          • charly2008C
                                            charly2008
                                            sorry i mad a mistake.
                                            Karlheinz
                                            • 2 / 3
