    Layout, External Reference
    layout
    3 Posts 3 Posters 2.1k Views 3 Watching
    • H Offline
      hfc07H
      To alow me to print off street elevations of my 3D model i have set up an A1 sheet on Layout, however, I have changed some things on my 3D model and have tried to update the reference.
      The reference information, i.e. date n time update but the model hasen't.
      In the reference dialogue box it says reference status embedded.
      Does this mean that when you have closed both files and gone back into them you can no loner update the file?
        bjanzen
        I responded in Google groups as well:
        Make sure your model is rendered if necessary (Auto, or Render button). Make sure the scene is correct. And relink if necessary.
        b
        • cmdC Offline
          cmd
          Currently, if you copy a model from one LayOut project and paste it into another LayOut project , the link to the 3D model is not preserved even though the model path displayed in the References area is correct. I dont know if this is what you did but, if so, this may be the reason you see the status as "Embedded". To establish the link, select "Unlink" and then "Relink".
          I hope this helps
          CMD
          • CMD
