    [Plugin] SCF Standard Toolbar (v1)
    8 Posts 5 Posters 12.6k Views 5 Watching
    • CadFatherC Offline
      CadFather
      Hi All
      here's another toolbar i made, it is the standard toolbar in one row with some tweaks, so not to everyone's flavour..
      Thanks! go to:
      Chris Fullmer: for sharing the standard views which are from his script.
      Matthieu Noblet: for his essential icon observer script (and support).
      Alz: for some fine icons.
      Jim Foltz: for the original idea and code examples.
      PS. i mean to work on Rick's toolbar system but i haven't had much time available, stay tuned though..
      Cheers
      Max
      SCF STANDARD TOOLBAR.zip
      • JClementsJ Offline
        JClements
        Hi Max:
        Thanks!
        Do you think a Bottom view icon could be added?
          CadFather
          ..your request fits in more with Rick's toolbars system, then you can decide what you want.. so hang in there
          otherwise this could look like the infinite story.. πŸ˜‰
          • W Offline
            wodur
            I think it could be very useful to post the mac version.
              What makes you think this is not suitable for a MAC ? Have you tried it ??
              • W Offline
                wodur
                I'm testing it on Mac. Most of the icons doesn't work and when I use once it remain pressed until I use it again. It's not a big problem because it doesn't affect to the functionality only appearence.
                The report of the icons is
                NOTE: I'm using Sketchup pro 8, spanish version. I'm using other plugins without problems
                (x) don't work ; (o) work ; ? I don't know what does but apparently doesn't work
                1. open (x)
                2. save (x)
                3. erase (x)
                4. import (x)
                5. export (x)
                6. copy (x)
                7. paste (x)
                8. new scene (o)
                9. delete scene (o)
                10. top view (o)
                11. front view (o)
                12. right view (o)
                13. back view (o)
                14. left view (o)
                15. x-ray vision (o)
                16. wire vision (o)
                17. hide lines behind vision (o)
                18. solid vision (o)
                19. solid with texture vision (o)
                20. monocrome vision (o)
                21. see/hide edges (o)
                22. profundity edges (x)
                23. colored edges (o)
                24. see or not hidden objects (o)
                25. ?
                26. ?
                27. shadows (x)
                28. shadow information (x)
                29. display layers (x)
                30. shortcut (x) "opens preference windows not the shortcut window"
                • W Offline
                  wodur
                  I have downloaded in this page a Mac version but more or less presents the same problems.
                  http://www.special.eclipse.co.uk/_ruby.html (can I post this web?)
                  I'm not sure but the author is the same person for both plugins?
                  • majidM Offline
                    majid
                    Thank you for update to version 8... I was waiting for it long time! πŸ‘
