    Help Me please - my sketch up is on hold
    6 Posts 4 Posters 747 Views 4 Watching
    • Z Offline
      zumo
      I am using sketch up 7 and it has been running o.k until now !
      as you can see from the picture it sort of cuts into walls and I dont know if its something I have done or a bug ?
      when I get close to the object I wont to add detail to it just disapeirs and shows me what is behind if you know what I mean!
      Many thanks
      Zumo.
        I'm guessing that your model is located far away from the origin. Or that you have some geometry very far of. SU doesn't deal with very large coordinates very well. You see this often if you for instance import a DWG of some plans which are located in real world coordinates. Moving the model closer to the origin should fix it.
          lucifer1101
          i also get this sometimes even though it is at the origin, restarting it usually fixes it...
          Some of my 3d
          • Z Offline
            zumo
            ounce again sketchucation has proven it is better to work together than alone!
            many thanks for your kind advise!
            zumo
              lucifer1101
              i like the look of your house there anyway looking forward to seeing a few renders....
              Some of my 3d
              • G Offline
                That's the "classical" clipping issue. Indeed, the model (physical) extent, like being far away from the origin is one of the main culprits - but there can be other reasons as well. Check out the link and possible troubleshooting/workarounds for the future.
