    Print to Scale [tutorial]
    13 Posts 7 Posters 1.6k Views 7 Watching
    • H Offline
      hfc07H
      Guys
      I'm using SU7 free version to compile a housing development of around 200 units. I have been exporting and using AutoCAD to produce the street elevations, however, it would be much simpler to just print the elevations straight from Sketchup.
      Ive been reading several posts on how to do it and it seams that you can only print to scale if you use the set views of left, right , top bottom etc by unckecking the "fit to page" dialoge box and set the perameters.
      Is it possible to print to scale once you have aligned to a specific face outwith the set views.
        No. Unfortunately - no matter you are still in parallel projection or anything. Even setting/aligning the axes to a "non-standard" view won't work.
        The only "solution" is to rotate the whole model to the standard scenes and take an export from there. It's like "when the mountain will not come to Mohammed, Mohammed will go to the mountain".
        • AnssiA Offline
          Anssi
          Now I don't remember who just a while ago posted this workaround (Thomthom?) using a section plane:
          • place a section plane and align your view to that
          • switch to parallel projection
          • in the Print dialog, check "2D section slice only"
          • SU lets you now set the print scale!
          • uncheck "2D section slice only". The scale box becomes grey but the setting sticks
          • click OK and print
          Anssi
            That's a good workaround - but it only works with the Pro version (AFAIK). See, now I stumped.
              Why does that only work for Pro? Printing isn't a Pro feature, is it?
                What I know is that section cut export is only pro but that's a dwg/dxf export so you are probably right - this should also work with the free version. Unfortunately I don't have the free installed on any computer I can access at the moment.
                • ely862meE Offline
                  ely862me
                  i m interested in this too..i ve made some cuts into the body of my car and i want to print those sectioncuts to scale..how do i do?
                  EDITED:Hehe scale 1:7 works πŸ˜„(keeping the 2d section cut only checked)
                  Elisei (sketchupper)
                  Come and See EliseiDesign
                  • EdsonE Offline
                    Edson
                    i am attaching an excerpt from aidan chopra's sketchup for dummies book, on the subject of printing to scale. i hope it helps.
                    printing to scale.pdf
                    http://www.mahfuz.arq.br
                    • P Offline
                      Prisoner
                      😍 Exactly what I've been looking for for my maps. Muchas gracias!!!
                      • ely862meE Offline
                        ely862me
                        URGENT....How can i save the pages which i want to print in A0 paper size..right now i have a normal printer and it only accept max A4..and how do i save it to give it like A0 format for printing it ???
                        Please if u know don t hesitate and tell me !!!
                        Thanks a lot!!
                        Elisei
                          Ely,
                          SU doesn't "save" images to paper sizes (it's just a "virtual world" that has nothing to do with our "physical world" such as a printout). You could however "print" them to scale into a pdf file with a virtual printer like PDFCreator and use the pdf files to take them to a printer which can print A0.
                          Or use SU Pro > LayOut.
                          (I'm sure I'll soon get percentage from Google πŸ˜„ )
                          • ely862meE Offline
                            ely862me
                            😍 it works πŸ˜„ Thanks a lot BOSS!!!
                            Another question :why it gives me empty pages near the one with the section..and how can i remove them..and how can i arrange the pages if the section is bigger than one A0 page format??
                            Hope i don t bother u too much! πŸ˜„
                            Elisei
                            Edited: just find the pdf splitter and merger πŸ˜‰
                            Thanks!
                              That's good because I wouldn't have known the answer as I have never tried to do this (just thought it would work) πŸ˜‰
                              So you spared me some trial and error playing around now. πŸ˜„
                              BTW SU Pro can also export to pdf and that's even vector based (unlike PDFCreator which will export a raster pdf only).
                              (Just trying to look nice at Google πŸ˜‰ )
