    Commandline Import DWG
    3 Posts 3 Posters 848 Views 3 Watching
    • H Offline
      HPW
      It would be nice if SU could be started with a DWG as the commandline parameter.
      Now it appears a messagebox: This does not appear to be a Sketchup model!
      It should open and import the DWG as it happens from the menu.
      • G Offline
        Gjenio
        Drag and drop dwg, images and what else, would be also really nice!
        • tbdT Offline
          tbd
          you can use SketchUp Bridge and send command Sketchup.active_model.import("file.dwg",false)
          SketchUp already supports dropped images & skp
          SketchUp Ruby Consultant | Podium 1.x developer
          http://plugins.ro
