Commandline Import DWG
It would be nice if SU could be started with a DWG as the commandline parameter.
Now it appears a messagebox: This does not appear to be a Sketchup model!
It should open and import the DWG as it happens from the menu.
Drag and drop dwg, images and what else, would be also really nice!
you can use SketchUp Bridge and send command Sketchup.active_model.import("file.dwg",false)
SketchUp already supports dropped images & skp
