    [Plugin] UV Toolkit
    377 Posts 86 Posters 376.0k Views 86 Watching
    • MALAISEM Offline
      MALAISE
      Never be to far from the Forum then you miss so useful Rubies.....
      Thanks Thom Thom ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
      MALAISE
      La Connaissance n'a de valeur que partagรฉe
      • troyhomeT Offline
        troyhome
        Thom Thom,
        Thank you so much for this ruby- it MUST appear in the next release of SU!!!
        IOviz.com
        SU Pro 2024 PC
        • N Offline
          notareal
          Nice one, thanks. Wish there was a way to "force" SU to use only quad-faces when using "auto-fold" or other tools.
            Aerilius
            Thanks!
            It's really good that someone makes texture tools that are not in this interlaced context menu.
            For future tools: It would be useful to transform a projected texture in a normal one (= to get the texture coordinates). So we could edit projected textures. I have often deleted the original face, so when another face with projected texture is not coplanar, there's now way to move edit the texture.
              Dandyman's OT posts split off and moved here:
              http://forums.sketchucation.com/viewtopic.php?f=80&t=19497&p=160663#p160663
              • free agentF Offline
                free agent
                thom is ther any way of making mirror textures global? max retains the mapping better if the textures are on both faces and its a schlep to go through each group
                http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                  A function that will mirror the material of all faces in a selection, drilling down into nested groups/components?
                    free agent
                    yup...can i get fries with that?
                    • urgenU Offline
                      urgen
                      ...thanks Thomas! ๐Ÿ‘.
                      --pupil forever...------
                        Well, Thom, time has come that I NEED the plugin and kept playing around with it. Simply amazing, I can tell. Thank you a lot again and here is something I've been playing around with (and a "special" material for the arch - included in the model probably along with a bunch of unpurged materials of Sang). ๐Ÿ˜„
                        Although for my (relatively thin bricks) in Roman arches, I'll need about twice as many quads than this one, it's already perfect (25 segments to make it smooth and the top segment flat but in fact, it didn't need to be flat as I realised). The rotate 90 and 80 degree commands (working on whole, smooth surface as well) are really handy and invaluable!
                        Arch.skp
                          Glad to see it working. ๐Ÿ˜„
                          • G Offline
                            gamore
                            Nice Tool ,Thanks
                              accabrera
                              Nice job!
                              Big thank you
                                remon_v
                                hey guys... I see some arch texturing here. I subdivided my arch in faces and now I want to texture my arch. I could do it manually by rotating the texture but maybe there's an easier way?
                                http://i22.photobucket.com/albums/b336/remon_v/uv-mapping.jpg
                                thnx in advance
                                  If you want to use it for rendering then you're better off creating a unique texture for it. V-Ray doesn't render skewed textures properly.
                                    remon_v
                                    oke thnx
                                      I think this plugin deserves some further attention and care so I made a little tutorial how you can get the final arch texture nicely mapped on a single face (not a series of facets divided by interior edges).
                                      See it here (and thanks Thom for this useful plugin again)
                                      • N Offline
                                        notareal
                                        Great tutorial Gaieus.
                                          Made some internal adjustments after learning how to get UV data from distorted textures. Bumped out of beta.
                                          1.0.0 - 15.10.2009
                                          * Merge with Mirror UV.
                                          * Correct sampling of UV data. Distorted textures now works.
                                          * Mirror material speed increase.
                                            Thanks - updated my plugin folder!
                                            ๐Ÿ˜‰
                                            • 18
                                            • 19
                                            • 3 / 19
