    [Plugin] UV Toolkit
    377 Posts 86 Posters 415.1k Views 86 Watching
      Aerilius
      It's really good that someone makes texture tools that are not in this interlaced context menu.
      For future tools: It would be useful to transform a projected texture in a normal one (= to get the texture coordinates). So we could edit projected textures. I have often deleted the original face, so when another face with projected texture is not coplanar, there's now way to move edit the texture.
      • GaieusG
        Dandyman's OT posts split off and moved here:
        http://forums.sketchucation.com/viewtopic.php?f=80&t=19497&p=160663#p160663
        • free agentF
          free agent
          thom is ther any way of making mirror textures global? max retains the mapping better if the textures are on both faces and its a schlep to go through each group
          http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
            A function that will mirror the material of all faces in a selection, drilling down into nested groups/components?
            • free agentF
              free agent
              yup...can i get fries with that?
              • urgenU
                urgen
                ...thanks Thomas! πŸ‘.
                --pupil forever...------
                • GaieusG
                  Well, Thom, time has come that I NEED the plugin and kept playing around with it. Simply amazing, I can tell. Thank you a lot again and here is something I've been playing around with (and a "special" material for the arch - included in the model probably along with a bunch of unpurged materials of Sang). πŸ˜„
                  Although for my (relatively thin bricks) in Roman arches, I'll need about twice as many quads than this one, it's already perfect (25 segments to make it smooth and the top segment flat but in fact, it didn't need to be flat as I realised). The rotate 90 and 80 degree commands (working on whole, smooth surface as well) are really handy and invaluable!
                  Arch.skp
                    Glad to see it working. πŸ˜„
                    • G
                      gamore
                      Nice Tool ,Thanks
                        accabrera
                        Nice job!
                        Big thank you
                          remon_v
                          hey guys... I see some arch texturing here. I subdivided my arch in faces and now I want to texture my arch. I could do it manually by rotating the texture but maybe there's an easier way?
                          http://i22.photobucket.com/albums/b336/remon_v/uv-mapping.jpg
                          thnx in advance
                            If you want to use it for rendering then you're better off creating a unique texture for it. V-Ray doesn't render skewed textures properly.
                              remon_v
                              oke thnx
                              • GaieusG
                                I think this plugin deserves some further attention and care so I made a little tutorial how you can get the final arch texture nicely mapped on a single face (not a series of facets divided by interior edges).
                                See it here (and thanks Thom for this useful plugin again)
                                • N
                                  notareal
                                  Great tutorial Gaieus.
                                    Made some internal adjustments after learning how to get UV data from distorted textures. Bumped out of beta.
                                    1.0.0 - 15.10.2009
                                    * Merge with Mirror UV.
                                    * Correct sampling of UV data. Distorted textures now works.
                                    * Mirror material speed increase.
                                    • GaieusG
                                      Thanks - updated my plugin folder!
                                      πŸ˜‰
                                        Did some experimenting today.
                                        Came up with a method that would texture selected quad-faces using a curve as a quide.
                                        At the moment it requires strips of quad-faces, and the guide has to be a welded curve. But before I release it I want to make it so it doesn't require the edges to be welded.
                                        Then, after the first release I'll see if I can extend it beyond being just strips of quad-faces. Maybe even make it texture triangulated quads.
                                        Anyway - here's the WIP shots. Whatcha think Gaieus? Something for you? πŸ˜„
                                        • N
                                          notareal
                                          Looks good!
                                          • jeff hammondJ
                                            whoa, that's definitely something i'll be able to use.. (and this is heading into the direction of the type of UV functionality i'd actually need in SU)
                                            in this example, it looks like it would work great along the top area as it's flat.. what about the curved areas near the bottom? (i drew this with a lot less segments for representational purposes.. an actually drawing would still be all quads though each one would be much smaller)
                                            • 18
                                            • 19
                                            • 3 / 19
