    Ruby console remember size between calls and sessions
    11 Posts 4 Posters 1.4k Views 4 Watching
    • H
      HPW
      It would be nice if the Ruby console could remember its size between calls and sessions.
      When I close and reopen it in one session it always gets a default size.
      The same is with separate sessions.
      • TIGT
        The Console's XY screen location is remembered in the registry BUT it seems it size is not...
        • Chris FullmerC
          It remembers its size on my machine. I run Vista. I also have Jim's Ruby developer plugin installed, but I don't use it really since it might have some Vista 64bit compatibility issues.
          Chris
          All my Plugins I've written
          • J
            Jim
            Yeah, that's one reason I made the ruby toolbar. It remembers the position and size of the Console.
            Windows only.
            • Chris FullmerC
              Aha! There you have it, it must be that that part of the script is working well (resetting it - emptying it does not work on my Vista machine though I think. I'll check again later).
              Chris
              • H
                HPW
                Hello Jim,
                Just download your ruby-toolbar and I will give it a try tomorrow.
                Is such added logik also possible for the DC 'Components options' window?
                Hans-Peter
                • J
                  Jim
                  @hpw said:
                  Hello Jim,
                  Hans-Peter
                  Well maybe, but I thought there was options in the DC Attributes Dialog to set the DC Options Dialog size. I can't look at the moment.
                  • Chris FullmerC
                    Your memmory serves you well Jim. There is in fact width and height controls built into DC's that control their component Options window. In the Component Attributes window, click on "Add attribute" and the options are at the bottom. Dialogwidth and Dialogheight.
                    • H
                      HPW
                      Chris,
                      Can you show the attributes (Dialogwidth and Dialogheight) looks in the dictionary? (I do not have SU 7 Pro yet)
                      Using this snippet:
                      Sketchup.active_model.selection[0].definition.attribute_dictionary('dynamic_attributes').each_pair { |k,v| puts k + '; ' + v.to_s }
                      from here:
                      http://www.sketchucation.com/forums/scf/viewtopic.php?f=289&t=18275
                      • H
                        HPW
                        Found it by try_and_error:
                          sel_def.set_attribute 'dynamic_attributes', 'dialogwidth', '460'
                          sel_def.set_attribute 'dynamic_attributes', 'dialogheight', '900'
                        • Chris FullmerC
                          Sure, this is from a simple dynamic component, that only has dialog height and widtrh asigned to it.
                          _dialogheight_label: DialogHeight
                          _dialogwidth_label: DialogWidth
                          _formatversion: 1.0
                          _has_movetool_behaviors: 0.0
                          _lastmodified: 2009-05-06 22:59
                          _lengthunits: INCHES
                          _name: Component#1
                          dialogheight: 560
                          dialogwidth: 345
                          nil
                          Hope that helps,
                          Chris
