    How to launch applications on Mac with Ruby?
    10 Posts 4 Posters 674 Views 4 Watching
    • W Offline
      Whaat
      On PC, I am using UI.openURL(file_path) to open an application or run a batch file. This does not seem to work on Mac. Or does it? How do you launch an application on a Mac with Ruby?
      Also, can you create and run a batch file on a Mac? Does Mac have something equivalent to batch files?
      Thanks!
        tomasz
        Hi Whaat,
        There was a thread dedicated to this issue.
        In SU2KT I do it this way:
        Thread.new do
        system(command options)
        I though it will allow KT to run without freezing the SU, but it works only for very limited time.
        I hope we can find proper way to do it on both systems.
        Tomasz
        • AdamBA Offline
          AdamB
          Ha. I find totally the opposite so in LightUp I have to do:
          UI.openURL("file;//" + File.expand_path(filepath)) if filepath and not(PLATFORM.include? "mswin")
          On (my test) PC, it just crashes.
          Un*x systems have very flexible 'batch files'. They can be arbitrary languages too but adding a line at the beginning of the batch file. Starting with:
          #!/bin/bash
          means run this batch file using this flavor of shell (aka Cmd.exe in Win32)
          • W Offline
            Whaat
            So this works to open an App or file on a Mac? (I can't test right now)
            • W Offline
              Whaat
              Hi Whaat,
              Thread.new do
                system(`command options`)
              Tomasz
              Thank Tomasz, I am aware of the thread but I did not see a solution that worked with Mac. I am able to launch Indigo with parameters using a batch file on a PC (the command window closes after execution) but I am trying to figure out how to do the equivalent on a Mac
                tomasz
                @whaat said:
                [I am aware of the thread but I did not see a solution that worked with Mac.
                I thought that
                works fine on Mac. At least I have had such an impression from posts from Mac users on KT forum.
                Unfortunately I have no Mac available to test it on my own.
                The method will probably block SU on MAC, so it is not a perfect solution anyway.
                Tomasz
                • AdamBA Offline
                  AdamB
                  OK, it looks like PC just can't handle being given a scheme handler. If you just give the path on PC it works fine. On the Mac, it (correctly in my book) expects a scheme handler for the URL.
                  Adam
                    works fine on a PC, if 'filepath' points to either an exe-file ora file-type... I don't see the issue ?
                    If you want to open a file with a particular app on a PC use a WinScript socket...
                    • AdamBA Offline
                      AdamB
                      Not on my WinXP laptop. Just crashes.
                        Works fine on my PC with Vista. Opens an app (.exe) or a file with it's assigned app...
                        Puzzling...
