    (Help) How To Make This Car
    4 Posts 3 Posters 587 Views 3 Watching
      moonlander1954
      Can someone teach me how to make this car please...
      Renault 5 (Cube).skp
      • ToboboT Offline
        Tobobo
        Moonlander,
        First I would create a cube using the rectangle tool and then the push pull tool.
        Looking at your model you have just created faces that don't match up.
        When you have a cube with the picture on should be able to trace the outline.
        I remember there being loads of posts about this.
        Have you tried searching the forum.
        I'm working on a quick and dirty tut for you but might be a couple of days (a bit busy at work)
        Sorry this was quick
        EDIT: Have a look at Rogue's tutorial here http://sketchup.google.com/3dwarehouse/details?mid=de3c151d9d1209fc5ef6f8ebfad7f16
        Toby
        Philippians 4:13
        • ToboboT Offline
          Tobobo
          To answer your message about aligning the faces see the images below.
          This the faces you created in the original file can you see the gap.
          Here is the rectangle I created then used the push pull tool. As you begin to model more you will need to start making sure that faces meet.
          hope that helps
          PS. Your english is better than my french. 😳
          Toby
          Philippians 4:13
          • ely862meE Offline
            ely862me
            u can take a look here too http://www.youtube.com/watch?v=GBI_SXWoOjc
            Elisei (sketchupper)
            Come and See EliseiDesign
