    Angled Push/Pull
    19 Posts 10 Posters 2.2k Views 10 Watching
    • D
      darkhelmet
      I 'sketched' a dog house (started as a simple box) with an angled roof - about 10 degrees up from back to front. I later decided to pull the edges of the roof out on all sides to make a little overhang after using the pencil to draw a small surface on all sides. The left and right sides went well but the front and back want to extrude straight ahead instead of along the same upward angle (in the case of the front) as the roof.
      Any suggestions?
      • ely862meE
        ely862me
        download the attachment and see
        ss.skp
        Elisei (sketchupper)
        Come and See EliseiDesign
        • R
          Rodentpete
          If I understand what you want to do correctly - don't use push/pull, just select the front face of the roof and use the move tool while you lock the direction of movement to the angle of the roof (hold shift while cursor is on roof edge)
          • D
            darkhelmet
            Got it although it might not be the correct way. Using the Tape Measure tool I pulled out a line from a corner at the front and the back the distance I needed. Then using your tip I was able to lock the 'Move' to the Tape Measure lines.
            Thanks!
            • GaieusG
              Also you can hold the Alt button down and use the PushPull tool (a fairly rarely used modification key for the PP tool πŸ˜‰ ). Note that the thickness of the roof ill also change slightly this way.
              • Jean LemireJ
                Jean Lemire
                Hi Darkhelmet, hi folks.
                See attached SU file for ideas.
                Inclined roof overhang.skp
                • ely862meE
                  ely862me
                  Thx Jean..i didn t knew that..
                  Elisei
                  • D
                    darkhelmet
                    Thank you and I will add this to my tool belt however it seems too many steps compared to what I did.
                    • jeff hammondJ
                      jeff hammond
                      yeah, Jean's suggestion is by far the fastest way to do this.
                      it might be a little more time consuming to get a set length though.. (ie pull out 14" then move it up and the actual overhang will now be longer than 14")
                      dotdotdot
                      • Chris FullmerC
                        But its prety speedy once you get it down. The whole video is 19 seconds, and that includes making all the doghouse shape, all in real time.
                        EDIT: This is Jean's method in action.
                        [flash=696,601:1inco4g9]http://www.chrisfullmer.com/forums/fix_planar.swf[/flash:1inco4g9]
                        Chris
                        All my Plugins I've written
                        • Jean LemireJ
                          Jean Lemire
                          Hi Chris, hi folks.
                          Thank you my friend. This video is worth a thousand pictures (or scenes).
                          Best regards.
                          • X
                            xrok1
                            actually if you make the top edge and front edge perpendicular like they will be if this is built for real, you can push\pull it to your hearts content. πŸ˜‰
                            β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                            • pbacotP
                              It is pulled straight up, so the length of overhang is still 14" (or whatever the horizontal pull is). "Around these parts" that is how overhangs are defined (on the horizontal, just like the rafter span).
                              xrok1, that's right, if one first tilts the top of the box, adds lines on the rake sides, then one can pull straight out at the correct angle. Many roofs are also made with the fascias on the vertical as in Chris's example. Dog house roofs are usually just a pc. of plywood.
                              (BTW how did you make that graphic with the floating ellipse?)
                              Gaieus, When I press the option key (alt) on the Mac, I get a push pull that leaves a plane at the original position. I don't see how it does as you say.
                              • GaieusG
                                For us, puny Windows users, the Ctrl key does that. But disregard my post: in this case it doesn't work as I tried out.
                                And hm... The SU Guide doesn't say a word about this in the Mac manual but never mind; neither in the Windows manual.
                                I don't know where it is (officially) documented. On the Windows, it practically works like as if you moved the face along its normal.
                                  Why not use the Didier Projection plug in one click! β˜€
                                  You have a PushPull Selected faces along their normal with a given measure πŸ˜‰
                                  (all that in 3 seconds from the initial object front and back facets selected and I am not Paganini πŸ’š
                                  Or Maybe I don't understand your problem πŸ˜’
                                  You have same function along any vectors if you want not the "normal" way πŸ˜‰ (left side icon of the "Normal" )
                                  • Jean LemireJ
                                    Jean Lemire
                                    Hi folks.
                                    See attached SU file for more ideas.
                                    Inclined roof overhang 2.skp
                                    • D
                                      darkhelmet
                                      @Chris Fullmer
                                      Nice and I stand corrected - that method is easier.
                                      @Pilou
                                      Where do I get this Didier Projection plug in?
                                      Thank you all for the great feedback!
                                      • X
                                        xrok1
                                        try Snagit screen capture software: http://www.techsmith.com/screen-capture.asp
                                          Projectionv6_zip by Didier Bur 😎
